H22a1 block w/ H22a4 crankshaft?
Old Jan 16, 2008 | 03:47 PM
cruizer's Avatar
Default H22a1 block w/ H22a4 crankshaft?
Does anyone know if a H22A4 crankshaft can fit in a H22A1 block....its being built for boost
Old Jan 16, 2008 | 05:08 PM
cruizer's Avatar
Default Re: H22a1 block w/ H22a4 crankshaft? (cruizer)
No one??????...i need to know because I want to start assembling the motor but i dont want to mess up anything when its done
Old Jan 17, 2008 | 11:08 AM
92civicx's Avatar
Modified by 92civicx at 5:51 AM 1/21/2008
Old Jan 17, 2008 | 02:12 PM
sewell94's Avatar
Default Re: H22a1 block w/ H22a4 crankshaft? (92civicx)
i don't remember which years they changed exactly, depending on which year a4 it is, some have different size mains, 5mm difference
Old Jan 18, 2008 | 06:06 AM
cruizer's Avatar
Default Re: H22a1 block w/ H22a4 crankshaft? (sewell94)
ok thanx alot
Old Jan 19, 2008 | 05:20 AM
BlkChryKord's Avatar
98's and up had 55mm mains I believe, to the 50mm of the earlier motors.
Old Jan 20, 2008 | 07:56 AM
Lubo_25's Avatar
sure you can make it fit...
you can bore out the tunnel bores and then hone them to 55mm no problem as long as crankshaft centreline is dead nuts centred otherwise kiss your oil pump and housing goodbye...
Old Jan 22, 2008 | 07:58 PM
cruizer's Avatar
Default Re: H22a1 block w/ H22a4 crankshaft? (Lubo_25)
damn....so basically i should just get a A1 crankshaft then?
Old Jan 23, 2008 | 04:43 AM
Lubo_25's Avatar
like i said if you want to go through the machining hassles then do the a4 if not stick with the original plan...the tunnel bores if done have to be perfect to accept the main bearing crush
Old Jan 24, 2008 | 06:09 AM
Could always try a H23 or F22 crank.
Old Jan 24, 2008 | 09:51 AM
cruizer's Avatar
Default Re: (BlkChryKord)
thanks but i really dont want to "try" those cause i dont want to break anything
mphirephox
Mar 4, 2011 11:56 PM
TodaSi
Dec 10, 2003 09:51 AM
rondigs
Mar 15, 2003 07:33 PM
Flamenco-T
Aug 14, 2002 07:37 PM
