ef8 front end help.
Old Jan 16, 2008 | 02:52 PM
j-speccr-x's Avatar
Default ef8 front end help.
If someone can help i have a crx with a ef8 front end and i was wondering if anybody knew what radiator support to use so i dont have to shim the rad support. someone please help washers look like crap.
Old Jan 16, 2008 | 03:18 PM
Zaakro's Avatar
Default Re: ef8 front end help. (j-speccr-x)
a japanese one from a non SiR with a SiR style front end
Old Jan 16, 2008 | 03:25 PM
EFin' Kyle's Avatar
lol Get the EF9 you have a hatch.
Modified by EFin' Kyle at 11:19 AM 1/20/2008
Old Jan 19, 2008 | 12:07 PM
j-speccr-x's Avatar
thanks guys.. do you know the vin like ef8 ef9 ?
Old Jan 20, 2008 | 10:15 AM
Zaakro's Avatar
Default Re: (j-speccr-x)
yeah
Old Jan 20, 2008 | 10:26 AM
tnez's Avatar
maybe you just need the jdm radiator(ef8)? since the fill/neck is recessed a little towards the firewall... maybe that will give you the extra clearance. I think the radiator supports are similar if not the same between a cr-x and a crx.
Old Jan 20, 2008 | 12:55 PM
j-speccr-x's Avatar
its a crx and i have tried both the ef8 one and the stock one.
Old Jan 20, 2008 | 01:11 PM
spun Vtec's Avatar
I used the usdm with no fitment problems at all no shimming needed. (my car did have front end damage before) But the ef8 one is the one that will work for sure. Your car must be whats out of wack if its not fitting correctly.
Old Jan 21, 2008 | 11:30 AM
Zaakro's Avatar
Default Re: (spun Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">I used the usdm with no fitment problems at all no shimming needed. (my car did have front end damage before) But the ef8 one is the one that will work for sure. Your car must be whats out of wack if its not fitting correctly.</TD></TR></TABLE>
that is not true.
https://honda-tech.com/zerothread?id=1700836
Old Jan 21, 2008 | 11:39 AM
spooncvc's Avatar
Default Re: (Zaakro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">
that is not true.
https://honda-tech.com/zerothread?id=1700836</TD></TR></TABLE>
Old Jan 21, 2008 | 01:42 PM
spun Vtec's Avatar
that is not true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncvc &raquo;</TD></TR><TR><TD CLASS="quote">
what exactly is not true?? I for 110% truth used my usdm T support and didnt do a damn thing. I have pics if you dont think I did. Ive also saw car's with the ef8 one installed, I just didnt know that it needed modified.
Old Jan 21, 2008 | 02:02 PM
spooncvc's Avatar
what exactly is not true?? I for 110% truth used my usdm T support and didnt do a damn thing. I have pics if you dont think I did. Ive also saw car's with the ef8 one installed, I just didnt know that it needed modified.</TD></TR></TABLE>
the hood latch must of been modified to be placed about an inch back to fit. i'll take pics of mine. unless your car was an 88
Old Jan 21, 2008 | 02:50 PM
spun Vtec's Avatar
Default Re: (spooncvc)
It was a 91 and your wrong. It was not modified.
here's a pic of it on my 91 crx.
Old Jan 22, 2008 | 10:48 AM
Zaakro's Avatar
yeah but you also said you have had front end damage. I am not saying you didn't use yours. What i am saying is from personal experience and what alot of others are saying is that you can not use a USDM or EF8/9 T support to latch your hood
Old Jan 22, 2008 | 10:54 AM
ukdm crx's Avatar
You need the 90-91 ef6, ef7 t-bar and everything bolts right up.
Old Jan 22, 2008 | 11:14 AM
spooncvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">It was a 91 and your wrong. It was not modified.
That picture does not do any justice. You are the very first CRX I know in many many years that DOES NOT have this problem. Unless you have an EF5,6,7 with SiR front T-bar or your car may have been bapped. The reason why I mentioned '88, is because, JDM CRX SiRs are actually 1988 CRX base chassis.
Old Jan 22, 2008 | 11:15 AM
spooncvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">yeah but you also said you have had front end damage. I am not saying you didn't use yours. What i am saying is from personal experience and what alot of others are saying is that you can not use a USDM or EF8/9 T support to latch your hood</TD></TR></TABLE>
yeap, i'm currently using a USDM T-bar. I had to modify the Hood latch! Booooz!
Old Jan 22, 2008 | 11:27 AM
BigDare23's Avatar
get the 90-92 ef7 or ef6 t- bar.
Old Jan 22, 2008 | 07:12 PM
j-speccr-x's Avatar
i thought what he posted was wrong. i couldn't remember which one to get. thanks guys a pearl white crx with a shaved bay, topmount with a shimmed t support doesn't look right
Old Jan 22, 2008 | 07:15 PM
j-speccr-x's Avatar
anybody have one for sale?
Old Jan 23, 2008 | 12:38 AM
spooncvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-speccr-x &raquo;</TD></TR><TR><TD CLASS="quote">anybody have one for sale?</TD></TR></TABLE>
I'll check my shop if we have one. No guarantees because we usually get EF8s. I'll send you a PM.
Old Jan 23, 2008 | 06:33 AM
~sp33~'s Avatar
EFB055
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncvc &raquo;</TD></TR><TR><TD CLASS="quote">The reason why I mentioned '88, is because, JDM CRX SiRs are actually 1988 CRX base chassis.</TD></TR></TABLE>
Base chassis? They used the same chassis from 87 -91. The EF chassis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnez &raquo;</TD></TR><TR><TD CLASS="quote"> I think the radiator supports are similar if not the same between a cr-x and a crx. </TD></TR></TABLE>
....lol.
Old Jan 23, 2008 | 10:28 AM
spooncvc's Avatar
Default Re: (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, they are base 88 EF CRXs, if you haven't noticed, the SiR seats will bolt straight onto 88-89 USDM CRXs and not 90-91 USDM CRXs.
Old Jan 23, 2008 | 10:38 AM
RockinthEFhatch's Avatar
Default Re: (ukdm crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ukdm crx &raquo;</TD></TR><TR><TD CLASS="quote">You need the 90-91 ef6, ef7 t-bar and everything bolts right up.</TD></TR></TABLE>THIS IS THE RIGHT ANSWER!
Everyone else doesn't have, or has a shitty looking JDM front.
Old Jan 23, 2008 | 04:27 PM
Zaakro's Avatar
Default Re: (RockinthEFhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">THIS IS THE RIGHT ANSWER!
Everyone else doesn't have, or has a shitty looking JDM front.</TD></TR></TABLE>
and my answer wasn't?
