vision carbon fiber hatch problem
whats up guys i just picked up my vision carbon fiber hatch for my eg and when i opened it i saw something funny. there isn't any hole for the lock, its just all carbon fiber. so im guessing i have to cut it and make the hole? im not sure whats the best thing to use since i never have cut carbon fiber and im sure it can be delicate. this happened to anybody else?
here are some pics
Modified by dblock at 2:24 AM 1/17/2008
here are some pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rclark »</TD></TR><TR><TD CLASS="quote">I just used a dremel on mine for all the stuff that wasn't already cut.</TD></TR></TABLE>
the carbon fiber didnt crack at all ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">eh- if i were u id package it up and send it to me... id even split shipping costs
leave me your address il ship it out by the weekend
</TD></TR></TABLE>leave me your address il ship it out by the weekend
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dblock »</TD></TR><TR><TD CLASS="quote">
Jesse T
536 palace court
nigeria
haha but really- be careful when just using the inner lock. the yelow peice on the cables deteriorate and snap- leaving you the only option to go outside and use the lock lol
</TD></TR></TABLE>Jesse T
536 palace court
nigeria
Use a dremel like mentioned with a small bit on it. The larger the bit the more chances of cracking. What cracks is not the carbon fiber. It's the resin. Use a dremel as a router and you will have no problems. If you try to drill a hole the size of your key cylinder, then that is where you start to have problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 Stunna »</TD></TR><TR><TD CLASS="quote">i would just eliminate the lock cylinder and use the hatch release on the inside
yea i was thinking about that but still debating
Jesse T
536 palace court
nigeria
haha but really- be careful when just using the inner lock. the yelow peice on the cables deteriorate and snap- leaving you the only option to go outside and use the lock lol</TD></TR></TABLE>
thats the only reason i actually want to put the lock there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disease »</TD></TR><TR><TD CLASS="quote">Use a dremel like mentioned with a small bit on it. The larger the bit the more chances of cracking. What cracks is not the carbon fiber. It's the resin. Use a dremel as a router and you will have no problems. If you try to drill a hole the size of your key cylinder, then that is where you start to have problems. </TD></TR></TABLE>
yea thats wat i was thinking of doing, im just iffy on it cause if it cracks im gonna be heated!
</TD></TR></TABLE>yea i was thinking about that but still debating
Jesse T
536 palace court
nigeria
i would drill a hole and use a dremmel to slowly widen the hole.
start off by outlining your circle and tape off anything you dont wanna ruin
dblock
22
Jan 20, 2008 05:33 PM
I3ooS710
Mar 1, 2007 07:28 PM
Chugger
Feb 7, 2002 01:43 PM
