95 gsr manual engine and trans into a 98 ls auto. HELP
cutting, messing with lots of wires....new mount locations....etc
list goes on
search
AUTO to MANUAL
there a quite a few threads with how to's
list goes on
search
AUTO to MANUAL
Will the obd1 manual engine harness plug into the 0bd2 auto car harness?
Im guessing all I need is a jumper harness so I can use my chipped obd1 ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedteg4dr »</TD></TR><TR><TD CLASS="quote">Will the obd1 manual engine harness plug into the 0bd2 auto car harness?
Im guessing all I need is a jumper harness so I can use my chipped obd1 ecu?</TD></TR></TABLE>
it should plug in.....
get a conversion harness for at the ecu
the complete 5 speed gsr tranny/engine, flywheel/clutch, manual axles, half shaft, shift linkage, 5 speed starter, clutch hard line, clutch slave and master cylinders, auto-manual tranny bracket or go to honda and purchase the weldable chassis bracket, 5 speed pedals, wire up vtecand IAB's, rear tranny bracket, torque mounts, 5 speed ecu. I think that covers most of it. when I did mine I didnt wire anything for the auto-manual. I just left the shift mechanism in park the whole time. hope this helps,Surge
NatedoggAZ
13
Nov 26, 2003 10:20 PM
