ecu pins b10 and b12
Im starting my mpfi swap, but i noticed on the ecu plug that only b10 is empty and b12 is not. is this normal?
Modified by thedudefromjerz at 1:39 PM 1/16/2008
yes thats normal
where did u get you info from?
what website
i have a website that is real good for this swap
i did mine but i am having idle issues
ill send the jawn as soon as i find it again
what website
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">swapping what into what?</TD></TR></TABLE>
He stated MPFI swap.
The FAQ at the top of the forum has many MPFI threads and even troubleshooting threads. Check it out.
dude i just did this and samething b12 was a white wire with red stripe.Just de pin it,tape it up and move it to the side.Thats what i did car runs good.The dude i did it for loves it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedudefromjerz »</TD></TR><TR><TD CLASS="quote">Im starting my mpfi swap, but i noticed on the ecu plug that only b10 is empty and b12 is not. is this normal?</TD></TR></TABLE> wire at B12 - white with red stripe is for the shift lock control on automatic transmission equipped cars - should be no wire at B12 on manual transmission cars
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote"> wire at B12 - white with red stripe is for the shift lock control on automatic transmission equipped cars - should be no wire at B12 on manual transmission cars</TD></TR></TABLE>
Sometimes there is however, and it is easy to just go ahead cut and splice, use the pin if it is there. One less to depin, one less pin that might make a poor connection.
jz2518
Dec 7, 2015 04:10 AM
Fo-Do Fanatic
Feb 19, 2010 12:15 PM
auto-x
May 8, 2003 09:18 AM
