Looking for a suitable clutch for b16a and b20VTEC
Old Jan 16, 2008 | 11:58 AM
slayerP's Avatar
Default Looking for a suitable clutch for b16a and b20VTEC
Among many things the clutch is going on my 88 CRX with a b16a and YS1 cable trans. Since the rings are damamged on this motor I plan on doing a b20/vtec coversion. What would be a good clutch to use for such an application? It's a street car, but i want something that'll grip.
As far as i know the drivetrain has about 115,000 km (70,000 mi) on it. Seems a little early for the clutch to go, could it be something else that's causing it to slip like a bitch?
Old Jan 17, 2008 | 06:16 AM
b16 snatch's Avatar
Default Re: Looking for a suitable clutch for b16a and b20VTEC (slayerP)
You only need a clutch that will hold the power your engine puts out. This is all you need: http://www.exedyusa.com/oe/08804
I got the stage two and it's entirely overkill on my b16. Even if you go b20/vtec this clutch will hold fine.
Old Jan 17, 2008 | 06:30 AM
JustAnotherRex's Avatar
Default Re: Looking for a suitable clutch for b16a and b20VTEC (b16 ******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16 ****** &raquo;</TD></TR><TR><TD CLASS="quote">You only need a clutch that will hold the power your engine puts out. This is all you need: http://www.exedyusa.com/oe/08804
I got the stage two and it's entirely overkill on my b16. Even if you go b20/vtec this clutch will hold fine.</TD></TR></TABLE>
Isn't that the wrong clutch? He said YS1 tranny, and that's a 90-91 clutch?
I've gotten myself into a mess here but I thought the 92-93 YS1 trannies had a different sized spline..
Old Jan 17, 2008 | 06:42 AM
b16 snatch's Avatar
Default Re: Looking for a suitable clutch for b16a and b20VTEC (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">
I've gotten myself into a mess here but I thought the 92-93 YS1 trannies had a different sized spline..</TD></TR></TABLE>
oops... you are right. http://www.exedyusa.com/oe/08800A. Thanks for correcting.
Old Jan 17, 2008 | 08:11 AM
solorex's Avatar
oops... you are right. http://www.exedyusa.com/oe/08800A. Thanks for correcting.</TD></TR></TABLE>
You guys have got me worried here. I have a JDM short ratio S1 tranny, I was under the impression I would need the 90-91 Integra Clutch. Is this correct?
Old Jan 17, 2008 | 08:39 AM
yobs00's Avatar
Default Re: Looking for a suitable clutch for b16a and b20VTEC (solorex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solorex &raquo;</TD></TR><TR><TD CLASS="quote">
You guys have got me worried here. I have a JDM short ratio S1 tranny, I was under the impression I would need the 90-91 Integra Clutch. Is this correct?</TD></TR></TABLE>
Yes that is correct 90-91 integra clutch.
Old Jan 17, 2008 | 08:45 AM
solorex's Avatar
Default Re: Looking for a suitable clutch for b16a and b20VTEC (yobs00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yobs00 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes that is correct 90-91 integra clutch.</TD></TR></TABLE>
Cool, thanks
Old Jan 17, 2008 | 11:17 AM
slayerP's Avatar
Well thanks for the resposnses, that points me in the right direction. So is my YS1 out of a GSR 92-93 or what is it out of. As far as I know it's JDM and ir really close ratio. And id there a chance i don't need to replace the stock clutch just yet?
Do I have to resurface the flywheel when I change the clutch or would it make sense to buy a lightened flywheel instead?
Old Jan 17, 2008 | 11:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayerP &raquo;</TD></TR><TR><TD CLASS="quote">Well thanks for the resposnses, that points me in the right direction. So is my YS1 out of a GSR 92-93 or what is it out of. As far as I know it's JDM and ir really close ratio. And id there a chance i don't need to replace the stock clutch just yet?</TD></TR></TABLE>
A USDM YS1 tranny can be either a GSR transmission or the far more likely candidate - an LS transmission. The only way to tell the difference would be checking the gear ratios by hand I believe, although I could be wrong on this.
A JDM YS1 I have no clues on. Search around?
And since you're pulling the longblock anyway, you can find out whether or not you need a new clutch when everything comes apart.
BumbleBee Tuna
Jun 23, 2007 08:13 PM
thatbluecrx
Feb 17, 2005 09:19 AM
DANgerous
Apr 4, 2004 01:37 PM
Slvr_CRX
10
Sep 3, 2003 12:40 PM
