Scratched cylinder wall...
Old Jan 16, 2008 | 11:30 AM
b16 matt's Avatar
Default Scratched cylinder wall...
How bad is too bad of a scratch in a cylinder wall to consider it too bad of a catch to not worry about? I mean i know it's always something to worry about, but damn I am broke and need a ride. I can feel the scratch, but my fingernail does not catch per-say... I think i did this when I blew my head gasket and the piston expanded when it overheated. I guess my question is can I put my head back on and drive this piece? Get back ASAP... Thanks
Old Jan 16, 2008 | 11:47 AM
b16 matt's Avatar
Default Re: Scratched cylinder wall... (b16 matt)
Old Jan 16, 2008 | 11:48 AM
b16 matt's Avatar
I searched BTW... For expletiveing hours.
Old Jan 16, 2008 | 12:09 PM
Schister66's Avatar
Man U FTW
Give us some details on the block...what bore? what engine??
Generally a small overbore will solve the problem. If you're on the stock bore right now, a .020 overbore will work fine and you can still find OEM parts to fit.
Old Jan 16, 2008 | 12:12 PM
b16 matt's Avatar
Default Re: (Schister66)
It has 84mm pistons and ductile iron sleeves in a b16 block. So, i am probably going to have to end up tearing this down?
Old Jan 16, 2008 | 01:30 PM
frankie99si's Avatar
Default Re: (b16 matt)
i rebuilt my ls block and i did a little boreing and there were still some small scatches but it was fine i have been driving it for a a while now with no probs
Old Jan 16, 2008 | 01:40 PM
NonovUrbizniz's Avatar
Loved
take pics... it's hard to judge by a description... chances are you'll be ok...
Did you cause the scratch when doing the HG or it was just there?
If it was just there then frankly I wouldn't worry about it... it was running before right?
IF it's something you caused while it was apart then it could be bad or not...
If your concerned more with money than time.. I'd say put it back together and see how it runs... do a leakdown test and a compression test... if it's F"d then take it back apart and repair it... if it's not at all or not too bad... drive on.
Is this an otherwise stock/stockish B16 or is it turbo or what?
Old Jan 16, 2008 | 02:12 PM
b16 matt's Avatar
Default Re: (NonovUrbizniz)
TUrboed at 16psi and put 400whp down and 300flbs of torque before it overheated...
Old Jan 16, 2008 | 02:35 PM
Loved
In that case I'd def. be a bit more concerned about the scratch...
Although IMO worst case is you put it back together and it burns some oil... which of course could lead to detonation...
It's a tough call man... it's always better to be safe than sorry...
But I'd probobly put it back together turn back the boost and see how it runs, check the plugs after a little bit... if the plug for that cylinder is soaked then you've got your answer...
if it's a small scratch chances are it'll just get worked out in normal running of the engine.
Best of Luck.
Old Jan 17, 2008 | 01:02 PM
eaither that or i would just rent the honning tool from autozone and take a litlle bit of thats what i did
ITRnorway
Sep 1, 2006 02:21 PM
B-B-K
Aug 9, 2005 09:01 PM
NyQuiL
May 5, 2004 07:42 PM
Desperado
Oct 4, 2003 09:07 AM
PrecisionH23a
Feb 4, 2003 03:33 PM
