Power windows for Crx
Old Jan 16, 2008 | 06:36 AM
vtecn8ive's Avatar
Default Power windows for Crx
I was curious as to what switches people are using for power windows in their Crx.
I have no plans to do a RHD conversion and would not want to get jdm door panels. maybe EDM?
but i was thinking of using the rear inside door handles from 88-91 Civic Sedan that have power windows.
man i hope that all made sense i'm going off of little amount of sleep and was brainstorming.
I have a good idea how to install the components but was interested in which switch people are using.
Thanks,
shane
Old Jan 16, 2008 | 06:39 AM
JustAnotherRex's Avatar
Default Re: Power windows for Crx (vtecn8ive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">I was curious as to what switches people are using for power windows in their Crx.
Thanks,
shane</TD></TR></TABLE>
There is an entire write up about this on CRXcommunity if there isn't one on HT.
Talk to Seti about getting UKDM power switches and you could get it done that way although it WILL NOT BE CHEAP. VTi panels are getting harder and harder to come by, power isn't any better. Although the leather in the VTi panels is beautiful.
Good luck!
Old Jan 16, 2008 | 09:55 AM
Zaakro's Avatar
Default Re: Power windows for Crx (JustAnotherRex)
EDM is the way to go. dont get UKDM because you will be in the same boat as if you got JDM.
Old Jan 16, 2008 | 10:03 AM
sikefcrx89's Avatar
Loved
Default Re: Power windows for Crx (Zaakro)
i am using the spal power window kit and the spal switches.. i love it and alot cheaper than trying to find almost 20 yr old stuff but if you have the money to throw away more power to you.. they do look clean
Old Jan 16, 2008 | 10:16 AM
stunn'd's Avatar
Im gonna use the main switch from the 4 door ef, Ill use the top two switches for the windows and the bottom two for locks.
If its any help to you, here's a diagram I drew up
Old Jan 16, 2008 | 12:24 PM
alscrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">EDM is the way to go. dont get UKDM because you will be in the same boat as if you got JDM.
I hope this guy i bought them from comes through, the LHD switches are nice!!
Anyone else selling ones?
I have seen the blockoff caps for the manual **** holes...did you get those?
Old Jan 16, 2008 | 01:49 PM
Zaakro's Avatar
Default Re: Power windows for Crx (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">
I have seen the blockoff caps for the manual **** holes...did you get those?</TD></TR></TABLE>
I have the door panels as well but i am waiting to switch to pillar mounted seat belts
Old Jan 16, 2008 | 09:06 PM
vtecn8ive's Avatar
Default Re: (stunn'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stunn’d &raquo;</TD></TR><TR><TD CLASS="quote">Im gonna use the main switch from the 4 door ef, Ill use the top two switches for the windows and the bottom two for locks.
Holy crap man thats an awesome idea. i was actually wanting power door locks too. Where do you plan to mount the main switch? and the passenger switch? I'm assuming you are going to leave the stock inside door handles alone then?
Also the EDM looks awesome, very tempting!
I gotta look into the SPAL kit... right now!
Old Jan 16, 2008 | 09:27 PM
n3h3bkau's Avatar
I decided to install a EK armrest and put my switches in there to cut out the middle man of having to install a separate switch for the passenger. Works pretty well using the 4-door window motors with the CRX window tracks.
Old Jan 16, 2008 | 09:49 PM
stunn'd's Avatar
Thanks, Im gonna mount the main switch in the same location as the 4dr's, I looked at the sedan door panels, all I would need to do is cut out a square like hole in front of the handle, and the main switch has a metal piece that screws to the back and sandwiches the door panel to hold itself in place. simple
As for the passenger side, I have a stock 4dr pass side switch shown in my diagram, however any rocker style switch could be flushed into the door panel.
I believe the 4dr switches would be the cheapest stock looking alternative (Auto down FTMFW).
For my old hatch I grabbed a set of canadian lhd switches, i think I paid about 10bucks for em.. but they went when I sold the car albeit, I found them rather brittle and flimsy much like cb7 handles. Not sure if the EDM would be of the same quality I experienced.
Old Jan 16, 2008 | 10:07 PM
vw eater's Avatar
looks good, ive been wanting to put power windows in my crx for a while now, i would like to see a nice write up on it also
Old Jan 16, 2008 | 11:15 PM
reydio's Avatar
Default CRX Power Windows
for the power window regulators, you can use an integra power window assy. from 91 to 94 or del sol from 92 to 95. they will bolt on without any problems. they are better than the 4 door ef since the spring tension is the same as our CRX. i used the spal switches to control them.
Old Jan 17, 2008 | 07:26 AM
thevtecnician's Avatar
Default Re: CRX Power Windows (reydio)
Wow nice! I have an 88 crx so I had the luxury of just bolting up the complete sir power door assemblies. The only thing tho is I can't seem to hookup my passenger side(jdm driver side) hopefully this diagram will help me. I was thinking about buying the edm lhd panels and switches and running the jdm pass. Side and edm pass side and having it like that with no master switch.
Old Jan 17, 2008 | 11:02 AM
nautica_t's Avatar
oh man, I use to love to go to meets, and show off my oem power windows lol.
Old Jan 17, 2008 | 03:17 PM
Mr Synister's Avatar
Where did you get or know where I can find that little Honda logo where the window handle use to be. I have that hole after I did my power window conversion.
Old Jan 17, 2008 | 03:49 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (Mr Synister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Synister &raquo;</TD></TR><TR><TD CLASS="quote">
Where did you get or know where I can find that little Honda logo where the window handle use to be. I have that hole after I did my power window conversion. </TD></TR></TABLE>
i have a complete LHD setup like that if anyone wants...
email only, my computer doesn't like pm's much
deetzcrx@gmail.com
The crank hole covers came as an oem part when the kits were installed here in Canada, but they are rare!!
Modified by Deetz at 6:48 PM 1/17/2008
Old Jan 18, 2008 | 12:43 AM
gsrpedro's Avatar
how much u want for the kit?
Old Jan 18, 2008 | 12:49 PM
vtecn8ive's Avatar
Default Re: (gsrpedro)
please keep for sale stuff in the for sale thread :D. although very tempting!
Old Jan 18, 2008 | 03:00 PM
Bsixteen_CRX's Avatar
Default Re: (vtecn8ive)
does anyone know if the edm crx's have door or piller mounted seat belts? i have a 1990 crx that i really want to put power windows in.
Old Jan 18, 2008 | 03:33 PM
bmg123's Avatar
Default Re: (Bsixteen_CRX)
pillar
Old Jan 18, 2008 | 03:39 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bsixteen_CRX &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if the edm crx's have door or piller mounted seat belts? i have a 1990 crx that i really want to put power windows in.</TD></TR></TABLE>
Just so you know, all 1988-91 civic and crx's in Canada came with pillar mounted seat belts. What does that have to do with your windows?
Old Jan 19, 2008 | 02:13 PM
vtecn8ive's Avatar
Default Re: (Deetz)
Probably wondering in case he uses the door panels
coffin on wheels
May 10, 2006 07:51 AM
EKCRX-Ihadastupidusername
13
Nov 22, 2005 08:43 PM
model x
Nov 14, 2002 11:06 AM
