Any other parts needed for overhaul work?
At 261K miles, my car is nearing it's next timing belt change. It also needs another clutch, and a new oil pan gasket.
Since all this work requires essentially removing all 5 mounts, I've decided to just pull the engine out completely and replace everything while the engine is out. I've put together a list of parts to buy for the job, looking to see if I left out anything or if anyone can suggest any other things while I'm at it.
Unless someone has a better suggestion, most all parts will be OEM Honda from Son's Acura.
- Oil pan gasket $20.64
- Front main seal $6.42
- Rear main seal $12.20 (2 part numbers available)
- Timing belt $43.14
- Water pump $100.64
- Tensioner pulley $56.42
- Tensioner spring $3.34 (2 part numbers available)
- Cam shaft seals $4.72 x2
- Valve cover gasket $7.56
- Plug tube gaskets (not listed at Son's for some reason)
- PCV valve (150K on my current one
) $13.28
- CV axle seal left $6.88
- CV axle seal right $8.08
Grand total from Son's $288.04 + shipping
Other parts:
- Exedy OEM clutch kit $129.73 from Import Replacement Parts (replacing my CM Stage 1 w/ almost 120K on it)
- Friction surface for my CM flywheel $104 from CM (unless someone knows where to get it cheaper)
That puts me at *gulp* $521.77 for everything.
I've also noticed in the past few months that my oil light comes on as normal when I first turn the key to start the car, then sort of flickers for a second before going off completely. Does this indicate that it's starting to go out? An oil pump would be another $136.74, but from what I understand the 98+ Integra oil pump (same for both R and non-R) will fit with slight modification to the lower timing belt cover, and it's less than $100 for some reason. Should I go that route? I guess it would definitely be easier to do it while the engine is out and timing belt is off, but that would send my total well over $600 for everything, and I'm kind of struggling to pay for all this stuff now. I want to get it done before the summer heat gets here, though.
So if anybody has any comments or suggestions on what I'm planning on doing, please let me know.
) $13.28- CV axle seal left $6.88
Other parts:
At that mileage it's no so much the pump as the bearing clearance.A new pump may make enough pressure to turn the light out at idle.It's really time for a real rebuild.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">At that mileage it's no so much the pump as the bearing clearance.A new pump may make enough pressure to turn the light out at idle.It's really time for a real rebuild.</TD></TR></TABLE>
Why is that? I still get 35 mpg highway and use maybe 1/2 quart of 5w-30 oil over the course of 3000 miles. I've never checked the compression on the engine, but it still seems to be running flawlessly.
I really don't have the time or money right now for a complete engine internal rebuild. It's my only car, and using my wife's car isn't much of an option with our current schedules, especially with my office about to move from 3 miles from home to about 12 miles in a few weeks.
hotcivicsi
13
Feb 26, 2009 01:35 PM
Mike VR6
35
Mar 2, 2007 03:23 AM
TRE_
May 3, 2006 06:32 AM
