condensation in trunk of del sol
Old Jan 15, 2008 | 05:27 PM
hermanssol's Avatar
Default condensation in trunk of del sol
Does anyone with a Del Sol ever have condensation inside their trunk lid? Has anyone ever insulated the inside of the trunk lid? Did that help with the moisture building up? Thanks for any advise.....
Old Jan 15, 2008 | 05:30 PM
NOFX's Avatar
H-T White Ops
Default Re: condensation in trunk of del sol (hermanssol)
Adding insulation isn't the answer. In fact, it might absorb water and make the problem worse.
You have a leak and probably standing water somewhere. You're going to need to find the source of the leak and fix it.
I hear a common location for leaks on del Sols is along the pillars next to the rear window. There's clips in there that get moved around or worn or something and then end up letting water in. You have to remove the liner around the outside to get to the clips and repair the issue.
Old Jan 26, 2008 | 05:42 PM
Annebelle's Avatar
I had a 94 del sol and there were pools in my spare tire and moisture every where. I didn't know how to fix it.
bigtom388
Mar 26, 2024 08:35 AM
RamaCRX
16
Oct 26, 2012 07:48 PM
cookiecrisp
Feb 16, 2009 03:15 PM
Del Sol on Steroids
10
Jul 12, 2007 04:15 PM
97grnrs
Jan 2, 2006 11:07 AM
