d16y8 swap idles jumping like crazy
Old Jan 15, 2008 | 02:32 PM
sky9's Avatar
Default d16y8 swap idles jumping like crazy
ok i need some help my idles is jumping for 1-3k up and down, and the butterfly platte on the TB is off a bit. there also a missing vaccum line that i dont know where it goes any body? note d16y8 motor in 1996 cx hb.
this is not my motor its just a picture that i can show you the vaccum line is missing the 1 circle in red
Modified by sky9 at 3:45 PM 1/15/2008
Old Jan 15, 2008 | 02:52 PM
sky9's Avatar
Default Re: d16y8 swap idles jumping like crazy (sky9)
ok throttle has been readjusted.
Old Jan 15, 2008 | 03:31 PM
chet baker's Avatar
Are you serious? frist replace the vaccum line
Old Jan 15, 2008 | 04:29 PM
sky9's Avatar
thats the thing i dont noe where that line goes to
Old Jan 15, 2008 | 06:44 PM
boostedjdmdc2's Avatar
so is that one that comes off the intake manifold?
Old Jan 15, 2008 | 06:53 PM
maddog20's Avatar
Default Re: (boostedjdmdc2)
that goes to PCV on the black box right above oil filter
Old Jan 15, 2008 | 07:07 PM
Mak Valley's Avatar
are you running obd 1 or 2? please elaborate on how your are doing either.
Old Jan 15, 2008 | 07:16 PM
yoffer's Avatar
Banned
Default Re: (maddog20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 &raquo;</TD></TR><TR><TD CLASS="quote"> that goes to PCV on the black box right above oil filter </TD></TR></TABLE>
The one cirlced in red doesnt go to the PCV on the block, the hose right above that goes there. I believe the once circled in red is the purge valve vacumme hose that runs into the carcoal canister? Correct me if i am wrong. But i do know that isnt the pcv hose. Either way, he should cap it off or find out where its running to and run a hose to it. Not having it capped off or something, will cause air to be sucked into the manifold and create a uneven flow of air going into the motor. The iacv is trying to compensate for the vacumme leak and thus, cause the idle to go up and down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by threewishmonkeypaw &raquo;</TD></TR><TR><TD CLASS="quote">are you running obd 1 or 2? please elaborate on how your are doing either.</TD></TR></TABLE>
The d16y8 are obd2 motors.
Old Jan 15, 2008 | 07:32 PM
sky9's Avatar
soo it goes to the carcoal canister any idea where that at? and you said to cap it off? when i put my finger over it, it seem like the motor wants to die.and ohh yah its a d16y8 with p28 ecu
thanks for the help
Old Jan 15, 2008 | 07:44 PM
yoffer's Avatar
Banned
You're running a p28 on a y8? How so? Did you cut the harness in the car (which should be obd2 considering the car is a 96') or are you running a conversion harness because the p28 is a obd1 computer. The ecu for the y8 is a p2p. The ecu that you are running is for a JDM d15b sohc vtec.
Old Jan 15, 2008 | 07:53 PM
sky9's Avatar
i used a conversion harness
Old Jan 15, 2008 | 08:27 PM
yoffer's Avatar
Banned
Well the vacume port runs to a solenoid that should be located right above the fuel rail and from the solenoid to the charcoal canister. Well at least, that's how it runs on my y8.
Old Jan 15, 2008 | 11:28 PM
Mak Valley's Avatar
yoffer, i know the y8 is obd2. but isn't it possible to run a p28 with all obd1 sensors making the setup obd1?
Old Jan 16, 2008 | 03:24 AM
yoffer's Avatar
Banned
Default Re: (threewishmonkeypaw)
Yes you can with the help of a conversion harness, but i was regarding a post from someone above stating whether or not it was obd1 or 2. The car (96' which is obd2) and the motor which is also obd2. I figured that he would be running a p2p ecu (obd2) which would be the most cost effective way to go.(no need to go buy a $75 conversion harness).
Old Jan 16, 2008 | 03:28 AM
polything's Avatar
the circle red part should go through a sensor then do to the canister (which located next to the battery.
you just finished the swap or wat?
Old Jan 16, 2008 | 03:31 AM
Mak Valley's Avatar
just re-read the first post.. i thought it was a 96 y8 swap (where that decision is necessary) and not y8 into a 96... whoops.
Old Jan 16, 2008 | 07:34 AM
sky9's Avatar
yah swap just been finished. hopfully this will fix my idle problem thanks
Baby99EX
Mar 31, 2017 05:34 AM
(760)doogie
Oct 18, 2008 05:05 PM
d16y8delsol
17
Feb 26, 2006 09:34 AM
kholmes
Feb 18, 2004 09:13 PM
