GSR cluster in EF: Speedometer not working?
Old Jan 15, 2008 | 01:05 PM
K2e2vin's Avatar
Default GSR cluster in EF: Speedometer not working?
I installed a GSR gauge cluster in my Civic. First; I had issues with the Fuel Gauge not working and found out that the cluster was different from the harness(on the cluster; fuel gauge was B1 and it was B3 on the harness).
Second, the speedometer doesn't work. I checked the wiring and it's correct. Only issue is it's reading 3.18-3.25v instead of 5v. Would this cause the speedometer to not work(in other words, is the VSS defective?)
Thanks, Kevin.
Old Jan 15, 2008 | 01:10 PM
GSX 4G63T's Avatar
Does the tachometer also work too? If no, I had the same problem. I blew #1 fuse underneath the dash and the whole speedo and tach didn't work, but the check engine light and other stuff worked. Check the fuse its a 10 AMP
Old Jan 15, 2008 | 01:33 PM
K2e2vin's Avatar
Yea, tachometer works. Everything works except the speedometer.
Old Jan 15, 2008 | 01:54 PM
GSX 4G63T's Avatar
VSS that's mounts on the tranny has a wire going inside the VSS, there is also a clip that secures it. May be that it came off loose.
Old Jan 15, 2008 | 04:54 PM
Tokyo's Avatar
Default Re: (4163175587)
swap your lead wires on your VSS i believe the powere wire is the middle one and the signal wire is the on the left and teh ground is on the far right oh yeah look at the VSS plug with teh flat side away from you.....hope this helps i did mine a few months ago and it works fine....make sure your also run a wire to your ecu or you will get a CEL for your VSS.....
PacManSol
Apr 23, 2012 09:29 AM
Skeero
Jan 18, 2012 07:51 PM
wcoupe94
Mar 27, 2008 10:18 AM
.BigSexy
Mar 13, 2007 09:26 PM
hedtrip
15
May 22, 2006 08:02 PM
