DOES ANYONE KNOW HOW SAFE WHEEL ADAPTERS ARE?!
Old Jan 15, 2008 | 12:29 PM
LAO's Avatar
LAO
Banned
Default DOES ANYONE KNOW HOW SAFE WHEEL ADAPTERS ARE?!
OKAY, SO IM PLANNING ON CONVERTING MY 4X100 TO 4X114.3 SO I CAN USE MY JDM ITR WHEELS ON MY INTEGRA?
http://www.pandagarage.com/Int...r.htm
HOW SAFE DO YOU GUYS THINK THESE ARE?
ANYONE TRIED THEM...I TINK IF IM JUST NORMAL DRIVING IT WOULD BE OKAY, BUT IF I WERE RACING OR TAKING OFF HARD, WHAT DO YOU GUYS THINK?
ANYONE FROM EXPERIENCE?!
THANKS
Old Jan 15, 2008 | 12:31 PM
Hiii Im TYLER's Avatar
eek. I wouldn't do it
Old Jan 15, 2008 | 12:32 PM
outdated's Avatar
always check if they are tight and you should be fine
Old Jan 15, 2008 | 12:35 PM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: (outdated)
i wouldnt use them on the track, but on the street there shouldnt be a problem
Old Jan 15, 2008 | 12:39 PM
Bury Your Dead's Avatar
* B A N N E D *
Default Re: (Chris.)
VW guys use those a lot. ask the same question on the vortex. use the high strength locktite on the part that goes into your stock hub.
Old Jan 15, 2008 | 12:41 PM
Markland Photo's Avatar
Default Re: (Bury Your Dead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bury Your Dead &raquo;</TD></TR><TR><TD CLASS="quote">VW guys use those a lot. ask the same question on the vortex. use the high strength locktite on the part that goes into your stock hub. </TD></TR></TABLE>
A lot of VW guys use it, should be good if you make sure its always tight.
Old Jan 15, 2008 | 12:42 PM
DUFFM4N's Avatar
they're safe if installed properly, make sure they're hubcentric (which they look to be in that pic u posted)....install them, drive around for a few days, then re-check everything to make sure its tight and nothing is moving/shaking
Old Jan 15, 2008 | 12:49 PM
sikciv666's Avatar
Default Re: (DUFFM4N)
WOW...those are pretty cool.
Old Jan 15, 2008 | 01:38 PM
sup gurl's Avatar
I want those for my Miata.
Old Jan 15, 2008 | 01:41 PM
Chronicsinners's Avatar
Default Re: (Markland Photo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Markland Photo &raquo;</TD></TR><TR><TD CLASS="quote">
A lot of VW guys use it, should be good if you make sure its always tight.</TD></TR></TABLE>
took the words outta my mouth
Old Jan 15, 2008 | 01:57 PM
OUT OF ORDER ROB's Avatar
isnt the 4x114.3 fairly cheap now though?
Old Jan 15, 2008 | 02:02 PM
pdxine's Avatar
I have been using mine for the better part of a year now with no problems. 20mm all the way around.
Old Jan 15, 2008 | 02:34 PM
* B A N N E D *
Default Re: (pdxine)
i used the 5 lug version on my gti so i could run audi a4 wheels to clear porshe brakes and i never had to touch them twice. actually it was the only thing on my car i didnt have to fix. everything else **** the bed.
Old Jan 15, 2008 | 04:28 PM
A-'s Avatar
A-
Default Re: (Hiii Im TYLER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hiii Im TYLER &raquo;</TD></TR><TR><TD CLASS="quote">eek. I wouldn't do it </TD></TR></TABLE> same die
Old Jan 15, 2008 | 04:30 PM
teggy182's Avatar
Default Re: (OUT OF ORDER ROB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OUT OF ORDER ROB &raquo;</TD></TR><TR><TD CLASS="quote">isnt the 4x114.3 fairly cheap now though?</TD></TR></TABLE>
fairly cheap yes. but good luck getting brakes for them.
Old Jan 15, 2008 | 04:42 PM
ChadB's Avatar
Buy H&R's adapters...
LAO
Feb 9, 2008 06:36 PM
Just_LS
Mar 28, 2007 11:51 PM
Overkill
19
May 16, 2006 06:37 PM
BLUE EH3
Suspension & Brakes
19
Oct 4, 2005 09:34 AM
.water
Dec 3, 2004 06:05 PM
