Ignition timing problem. Help!!!
Old Jun 30, 2002 | 08:59 PM
joedr's Avatar
Default Ignition timing problem. Help!!!
Hi!!
I was reading the Shop Manual for a B16A first Generation (Using PR3 ECU) and went over to the timing setting's pages. They said that you must connect two wires (GRN/WHT and BLU) from the ECU before the adjustment. I did that but here are my two questions/problem:
1. What exeactly the two cables together do to the timing system/ECU that you must connect them togeter?
2. Why my timing is really away to the actual red mark? It really do not matter how much I advance/retard the ignition, never get even close to the red mark, only the white mark is the one that I can see with the light.
Here is the actual reading:
- White mark
- Timing light on pointer
- Red mark
This is around 700RPM.
As you can see, the actual reading sees the white mark over the pointer, but no matter how I move (advance/retard) the distributor, never got the pointer near the red mark.
I will appreciate any help on this matter!!
Kaleb_Johnson
Jul 3, 2014 12:19 PM
jorgep82
Nov 28, 2013 03:58 AM
jdurston
Jun 9, 2004 05:30 AM
joedr
Jul 6, 2002 05:36 PM
JSpecwest
Jan 4, 2002 06:22 PM
