B20 swap wiring HELP!!!!
Old Jan 14, 2008 | 10:54 PM
sepetinswenze's Avatar
Default B20 swap wiring HELP!!!!
I did a search but could not find exactly what i needed... please help...
Ok i got a 1999 Honda Civic EK, with D16 pulled and will be replaced with a 1998 CR-V B20b engine which is Jackson Racing Supercharged, and has DSM 450 injectors with resister box.
I need help with the wiring... I understand that the car and engine are both OBD2, but i only have an OBD1 LS ECU to run the engine (Hondata)... And i don't really want to pull the civic wiring out if i can avoid it.
Do i only need the OBD1 - OBD2 conversion wiring? or more?
What do i need to do to make this baby run???
And one last thing... what motor mount do i need to replace?
Old Jan 15, 2008 | 07:08 AM
Default Re: B20 swap wiring HELP!!!! (sepetinswenze)
cummon... someone must know? please help... its my daily driver. need it.
Old Jan 15, 2008 | 09:13 AM
random name's Avatar
You only need the OBD1-OBD2 wiring
Old Jan 15, 2008 | 09:31 AM
Default Re: (random name)
Really??? thats great... thanks
Old Jan 15, 2008 | 06:32 PM
I AM WEASEL's Avatar
you don't need obd1 to obd2 wiring. what you need is an obd2b to obd1 ecu jumper harness as well as the t bracket and the drivers side mount bracket from a 99-2000 civic si.
Old Jan 16, 2008 | 04:21 AM
Default Re: (-DC4-)
thanks man... i will get right on it...
Old Jan 22, 2008 | 09:19 AM
Deadmoans's Avatar
Default Re: (sepetinswenze)
Ok tried to do a search. Maybe someone can help. Putting a '95 CRV B20 in a '93 civic coupe ex. What ECU to use? Will a LS ECU work? Do the pins match from the CRV to the EX? In otherwords, I believe the connectors are the same for the wiring harness, but do the wires match on the two cars?
Old Jan 22, 2008 | 01:46 PM
cetcivic's Avatar
no one wants to hear the truth
obd1 ecu
advan414
Feb 24, 2008 04:41 PM
ludesrv
Sep 3, 2006 08:21 PM
THugluv423
Jun 4, 2006 06:02 PM
hybridb18
Feb 1, 2003 09:30 PM
