Removing lower grill on 99-00 bumper
Old Jan 14, 2008 | 10:49 PM
JSiRTO's Avatar
Default Removing lower grill on 99-00 bumper
After searching quite a bit, I couldnt find a definate answer on how this has been done. Looking for some insight into whether you have simply cut the tabs off, sanded & repainted or cut out the entire area that stays unpainted. Pics with your method would be great as well. TIA.
Old Jan 15, 2008 | 04:08 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Removing lower grill on 99-00 bumper (JSiRTO)
Iam sure everyone just cuts them out... Just cut out what you want out.
Old Jan 15, 2008 | 04:36 AM
yoffer's Avatar
Banned
Default Re: Removing lower grill on 99-00 bumper (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Iam sure everyone just cuts them out... Just cut out what you want out.</TD></TR></TABLE>
x2
Old Jan 15, 2008 | 06:19 AM
Libertariat's Avatar
Ek Forever y0!
Yep, just cut it out. Cover it with some black painted mesh.
Old Jan 15, 2008 | 06:36 AM
OMGWTFBBQ!'s Avatar
Mine was just cut out and left that way, I like the way it looks.
I also removed the two small side vents with a hot-knife and a dremel.
Modified by OMGWTFBBQ! at 11:45 AM 1/15/2008
Old Jan 15, 2008 | 08:11 AM
.:Swig:.'s Avatar
Default Re: (OMGWTFBBQ!)
i cut mine with a razor blade,
Old Jan 15, 2008 | 12:27 PM
NOFX's Avatar
H-T White Ops
Why cut it out? I could see trimming for clearance, but I think they look bad with a big gapping hole at the bottom.
Old Jan 15, 2008 | 01:00 PM
hgem1si's Avatar
Default Re: (NOFX)
The guy I bought my em1 off of did it... Pretty sure he took a dremel to it, the cut is kind of nasty. He filled it with silver mesh, I painted it black. Definitely if you're going to do it paint the mesh black, or leave the hole empty. I stuck my license plate down there to try to hide it.. lol.
Old Jan 18, 2008 | 09:29 AM
arihakan's Avatar
if, for example, you cut it. wont the lower part of the bumper droop? or slightly go up without the original part there holding it up/down? let me know cause i want to cut my lower grill too but i dont want it to droop/go up. thanks
Old Jan 18, 2008 | 09:36 AM
.:Swig:.'s Avatar
Default Re: Removing lower grill on 99-00 bumper (arihakan)
i never had any problems with its shape. Only thing was that it was more flemsy, but not by that much.
Old Jan 18, 2008 | 10:17 AM
smileycvc's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">Why cut it out? I could see trimming for clearance, but I think they look bad with a big gapping hole at the bottom.</TD></TR></TABLE>
Unless you fill it with an intercooler
Old Jan 18, 2008 | 10:24 AM
93egSLEEPER's Avatar
Default Re: (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">
Unless you fill it with an intercooler </TD></TR></TABLE>
that is exactly what i was thinking.
Old Jan 18, 2008 | 11:08 AM
vtecpoweredsol's Avatar
i had to take mine out to fit my intercooler...
cut the bitch
Old Jan 18, 2008 | 11:37 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">Unless you fill it with an intercooler </TD></TR></TABLE>
I'd still trim it if I could (in fact, I'd shop for one that would fit with just minor trimming).
I think they look cheap with the whole thing cut out.
Old Jan 18, 2008 | 09:25 PM
boost4life's Avatar
the best way for me so far is a air cutoff wheel then i used a file for a nice square edge and sanded it with a med grit papper (600)ish for a clean fin
Old Jan 18, 2008 | 11:36 PM
jasony0630's Avatar
76.26.106.124
hell, i cut that off a long *** time ago...only used a hand saw lol....i think it looks nice
Old Jan 19, 2008 | 12:03 AM
Dramier's Avatar
Default Re: (vtecpoweredsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpoweredsol &raquo;</TD></TR><TR><TD CLASS="quote">i had to take mine out to fit my intercooler...
cut the bitch</TD></TR></TABLE>
x2...
Oh and trim the sides for the IC piping too...
SovXietday
Jul 21, 2007 05:51 PM
Ryan.
Northeast (Sales)
11
Aug 1, 2006 09:10 AM
EJ8VTEC
Oct 1, 2005 08:11 PM
Weapon_R
15
Sep 10, 2005 04:00 PM
silvrEK
Aug 27, 2004 01:21 PM
