Manual transmision fill/check plug
Old Jan 14, 2008 | 08:02 PM
TokyoStatus's Avatar
Default Manual transmision fill/check plug
Ok so I drained my transmission oil but cant get the fill plug off. So its sitting on jack stands with no tranny fluids. I need to be able to drive. Used a wrench at first then a socket wrench and breaker bars for leverage. Still stuck tight!!!! Any suggestions.
-Thanks in advance.
Old Jan 14, 2008 | 08:06 PM
994door's Avatar
Default Re: Manual transmision fill/check plug (TokyoStatus)
i usually fill it from the vss. but still you need to take the fill plug off. so i'm not really any help. but double check, righty tighty lefty loosey
Old Jan 14, 2008 | 08:08 PM
Rok_Stok's Avatar
WD40, PB Blaster, and remember to push on the breaker bar/ratchet in short strong bursts to break it loose. You can always push harder than you can pull, and doing it in one long push doesn't always get the job done, you have to beat at it like an impact wrench does. And you probably already know all this, so there's my $0.02.
Old Jan 14, 2008 | 08:14 PM
994door's Avatar
Default Re: Manual transmision fill/check plug (Rok_Stok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rok_Stok &raquo;</TD></TR><TR><TD CLASS="quote">WD40, PB Blaster, and remember to push on the breaker bar/ratchet in short strong bursts to break it loose. You can always push harder than you can pull, and doing it in one long push doesn't always get the job done, you have to beat at it like an impact wrench does. And you probably already know all this, so there's my $0.02.</TD></TR></TABLE>
exactly... try hitting the tip with a hammer. thats what I had to do to get a bolt off one time. Turn while a friend hits it.
Old Jan 14, 2008 | 08:16 PM
yea ill try some stuff my friend used to loosen up the bolts on his turbo. I didnt use wd-40 yet and ill do short bursts. Anything else guys?
Old Jan 14, 2008 | 08:18 PM
Default Re: Manual transmision fill/check plug (994door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door &raquo;</TD></TR><TR><TD CLASS="quote">
exactly... try hitting the tip with a hammer. thats what I had to do to get a bolt off one time. Turn while a friend hits it. </TD></TR></TABLE>
so hit the socket while applying force or just hit it then try turning.
Old Jan 14, 2008 | 09:27 PM
anomoly553's Avatar
you can try to heat it with a torch, personally id put a cheater bar ( a piece of conduit) on your ratchet, and pull it
Old Jan 15, 2008 | 03:31 AM
994door's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TokyoStatus &raquo;</TD></TR><TR><TD CLASS="quote">
so hit the socket while applying force or just hit it then try turning.</TD></TR></TABLE>
hit the socket while applying force.
Old Jan 15, 2008 | 04:22 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I'd just remove the 10mm bolt that holds your vehicle speed sensor in and fill it from there. The tranny has a vent tube to allow the air displaced by the fluid to escape.
A B series tranny holds about 2.3 quarts of MTF, so basically pour just under 2.5 quarts into it.
Modified by B18C5-EH2 at 8:34 AM 1/15/2008
Old Jan 15, 2008 | 04:25 AM
Civicman86's Avatar
You want to just hit it. Your trying to get a large change in torque hoping it will break loose. Much like an impact gun does.
Old Jan 17, 2008 | 07:35 AM
Default Re: Manual transmision fill/check plug (B18C5-EH2)
thanks thats what im going to end up doing. If i had a lift I could probably get enough room for a longer pipe or something. But on my jackstands I dont even have room to push so ive only been pulling on it.
Old Jan 17, 2008 | 08:27 AM
blk92_d16's Avatar
Just put the fluid in through the vss!
Old Jan 17, 2008 | 10:12 AM
3lo's Avatar
3lo
try reaching it from under the hood with socket wrench, and slide on a long pipe to get leverage. but ye vss is almost same level as the fill up hole.
kp3ft
Classic Hondas
Dec 15, 2008 03:17 PM
vat0213
Honda Civic (2001 - 2005)
Jul 15, 2007 03:48 AM
vtec.dc2
Apr 3, 2007 06:47 PM
SimbaDogg
Dec 21, 2003 06:25 AM
Matgallis
Nov 10, 2003 01:19 PM
