b16a2 water bypass connection
Old Jan 14, 2008 | 07:55 PM
ben1284's Avatar
Default b16a2 water bypass connection
where do i connect the small metal tube that is behind the upper radiator hose to? there is supposed to be a hose called water bypass, a coolat line..., and I don't have an oil cooler.... helms diag. repair manual doesn't make sense....thanks
Old Jan 21, 2008 | 01:03 AM
EnjoyTheRideDC2's Avatar
Default Re: b16a2 water bypass connection (ben1284)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben1284 &raquo;</TD></TR><TR><TD CLASS="quote">where do i connect the small metal tube that is behind the upper radiator hose to? there is supposed to be a hose called water bypass, a coolat line..., and I don't have an oil cooler.... helms diag. repair manual doesn't make sense....thanks</TD></TR></TABLE>
Do you have the OEM stock intake box or did you just install an aftermarket intake?
Old Jan 21, 2008 | 01:15 AM
Better yet, here's your answer....
integrawow
Jan 1, 2008 03:05 PM
JCracer723
Jan 17, 2007 07:04 PM
max8455
Jan 10, 2005 05:04 PM
b18cEF9
Nov 5, 2004 12:44 PM
90crxzc
Dec 20, 2003 08:27 AM
