Need some motor mounts/Energy suspension motor mount inserts or innovate billet aluminum solid mount
Old Jan 14, 2008 | 07:13 PM
Markb16a's Avatar
Default Need some motor mounts/Energy suspension motor mount inserts or innovate billet aluminum solid mount
I think its about time for motor mounts sohc turbo and well I need mounts bad. so what would you guys do? what would work and what wouldnt? I would like to get innovate but how good are the motor mount inserts? Has anyone tryied them? If so what is the feedback from them? Thanks.
Old Jan 15, 2008 | 09:25 AM
Markb16a's Avatar
Default Re: Need some motor mounts/Energy suspension motor mount inserts or innovate billet aluminum solid m
bump
Old Jan 15, 2008 | 09:58 AM
Andyroo's Avatar
if u cant afford hasport get innovative. or just fill them with 60A+ polyurethane, i found all to work great. if ure going to fill them make sure you allow at least three days for them to cure, might even have to poke little holes with a needle to allow oxygen to get in unless u mixed it with some sort of hardener
Old Jan 15, 2008 | 11:27 AM
EG_H2B's Avatar
Innovative makes the best mounts. I have used them many times with no problems. Great customer service too.
Old Jan 16, 2008 | 06:50 AM
Markb16a's Avatar
so what hardness are you running 62a? or harder and if so how is the inside cabin shake? I know when I did have hasports for my crx it was rattle everywhere but the motor didnt move at all.
Old Jan 16, 2008 | 08:18 AM
EG_H2B's Avatar
I have the 85A and I dont think it vibrates that much. But I havbe used 60As on customers cars and it feel like an OEM mount. Innovative has the least amount of vibration. The 62A Hasports that I have used vibrate the car more then the 85A Innovatives.
Old Jan 16, 2008 | 09:15 AM
Markb16a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_H2B &raquo;</TD></TR><TR><TD CLASS="quote">I have the 85A and I dont think it vibrates that much. But I havbe used 60As on customers cars and it feel like an OEM mount. Innovative has the least amount of vibration. The 62A Hasports that I have used vibrate the car more then the 85A Innovatives. </TD></TR></TABLE>
maybe I should go with the 75 or 85a if it dosent shake like the hasport mounts with 60a but this is daily driver though.
Old Jan 16, 2008 | 09:16 AM
Markb16a's Avatar
Default Re: (Markb16a)
so its better to have a solid mount when you run slicks? or what? That is kinda been on my mind lately?
Old Jan 16, 2008 | 11:45 AM
crazyguy's Avatar
hasport mounts make the best mounts and they are very stiff. u will feel your car vibration cause they are firm. if u like quiet and smooth . go with the oem
Old Jan 16, 2008 | 01:39 PM
Andyroo's Avatar
Default Re: (crazyguy)
civicsi18
Oct 27, 2008 12:05 PM
george34
Dec 9, 2005 06:52 PM
rocketfuelcerx
Apr 8, 2005 11:53 AM
JUN JDM
Jul 13, 2003 08:11 PM
