I am having a tough time programming my 2W900FM 2ND (Blue Remote)
Old Jan 14, 2008 | 06:58 PM
Azxster's Avatar
Default I am having a tough time programming my 2W900FM 2ND (Blue Remote)
I had recently had my Civic installed with the 2W900FM. I was initially given the gray remote with the turbo timer until the blue remote with the 2ND feature arrived. I activated it to 2ND and am trying to have my dad's car, CR-V with the 2W900FM-AS (older blue remote (rectangular rather than curvey)) to learn the new blue remote.
I turn ign on/off 5 times...
Press 1 on old blue remote, clicks
Press 1 on new remote with 2ND enabled, nothing
Am I doing something wrong? Is the new remote not compatible with the old 2W900FM? Is my new remote defective? When I change it back from 2nd to normal, it would unlock my Civic.
Old Jan 15, 2008 | 06:43 PM
fastcrvi's Avatar
Default Re: I am having a tough time programming my 2W900FM 2ND (Azxster)
dont know if antenna wiring is same.. if it is, then you might be able to make it work by swapping the antenna from you civic onto crv. did you install it yourself? if not, just take it to installer. basically, your remote/antenna needs to be compatible with brain module, if not it will not work. or theres a different programming sequence for old compustar. i really don't know much about older units or differences.. just throwing stuff out there.
Old Jan 16, 2008 | 05:48 AM
fcm's Avatar
fcm
Old Fart
Not sure I fallow, the "rectangular rather than curvey" remote is a 2WFMR, or maybe a 2WSSR
Go to... http://www.compustar.com/main.htm click on Remote User Manuals to confirm what remotes you have. 94
Old Jan 16, 2008 | 07:45 AM
Azxster's Avatar
Default Re: I am having a tough time programming my 2W900FM 2ND (fcm)
CR-V:
Civic
Why would I swap antenna? I want to use it for both cars.
Damn, I thought both were 900FM...
team1320_k26eg
Audio / Security / Video
10
May 8, 2008 08:37 PM
95GSRBOI
13
Sep 6, 2007 09:40 PM
clear0614
Aug 9, 2005 05:07 PM
Fuster_Cluck
Aug 9, 2003 04:10 PM
jdwebmaster
Jul 21, 2003 07:56 PM
