HELP! Broken Clutch Pedal Bracket??
Old Jan 14, 2008 | 05:14 PM
i_VTEC's Avatar
Default HELP! Broken Clutch Pedal Bracket??
Ok here it goes. I was driving to my friends house when i noticed every time i tried to change gears it was hard to put my car into a gear. It felt like the clutch stayed engaged and did not disengage as far as it should. I noticed my clutch pedal was a little cricked and didn't go in as far as it should. When i got home i looked under the dash and saw this....
I need to get this fixed ASAP! because i attend College and this is my only ride.
What all do i need to remove to fix this? Whats the easiest way to do this without taking out a bunch of things? Anything you guys can help me with will do!
Thanks again Honda-Tech friends!
Old Jan 14, 2008 | 05:18 PM
sirtef9's Avatar
Default Re: HELP! Broken Clutch Pedal Bracket?? (i_VTEC)
unbolt the 4 12 mm nuts, Theres 2 of them to the right of it in the pic. Then go pull one at your local Junk Yard
Old Jan 14, 2008 | 05:20 PM
CRX Toad's Avatar
It is pretty common problem. There is lots of other threads on it. It definitely sucks.
Old Jan 14, 2008 | 05:21 PM
GSX 4G63T's Avatar
Default Re: HELP! Broken Clutch Pedal Bracket?? (sirtef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 &raquo;</TD></TR><TR><TD CLASS="quote">unbolt the 4 12 mm nuts, Theres 2 of them to the right of it in the pic. Then go pull one at your local Junk Yard </TD></TR></TABLE>
That too or if you have a welder weld that baby back to health.
i_VTEC's Avatar
Default Re: HELP! Broken Clutch Pedal Bracket?? (CRX Toad)
I know i have to unbolt those 4 Bolts, But what else do i need to unbolt or take off? I'm sure it doesn't just slip right off though...
Old Jan 14, 2008 | 05:23 PM
i_VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">
That too or if you have a welder weld that baby back to health. </TD></TR></TABLE>
Thats what i was thinking. But will it work or will it break again pretty easily?
Old Jan 14, 2008 | 05:35 PM
sirtef9's Avatar
grab a flashlight and take off the gas pedal cable and clutch cable under the dash,
Old Jan 14, 2008 | 05:37 PM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Thats what i was thinking. But will it work or will it break again pretty easily?</TD></TR></TABLE>
USE GAS MIG WELDER to form a puddle of weld to form a very strong bond
Old Jan 14, 2008 | 05:46 PM
i_VTEC's Avatar
Default Re: HELP! Broken Clutch Pedal Bracket?? (4163175587)
Would that be the easiest thing to do? Or should i just grab another one from a local Junk Yard?
Old Jan 14, 2008 | 05:49 PM
GSX 4G63T's Avatar
if you live the heck far from a junkyard i would do this welding. if you live a block then go get it quick.
Old Jan 14, 2008 | 05:50 PM
sirtef9's Avatar
if your gonna pull it to weld it, why not replace it with a good working piece instead?
Old Jan 14, 2008 | 05:53 PM
i_VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 &raquo;</TD></TR><TR><TD CLASS="quote">if your gonna pull it to weld it, why not replace it with a good working piece instead? </TD></TR></TABLE>
Well thats what im saying. If its gonna be a hassle to get it out then i might as well weld it. But then again i live down the street from a Junk Yard so im sure i could get another one. I think welding it would be easier though wouldn't it?
Old Jan 14, 2008 | 05:57 PM
GSX 4G63T's Avatar
Well thats what im saying. If its gonna be a hassle to get it out then i might as well weld it. But then again i live down the street from a Junk Yard so im sure i could get another one. I think welding it would be easier though wouldn't it?</TD></TR></TABLE>
if you know how to weld i mean have a good skill on it then do it on the car. If you can't weld and don't have sturdy hands you mights weld a loom of wires and start a fire. Get a used one from the junkyard if you know you can not weld ok.
Old Jan 14, 2008 | 06:19 PM
i_VTEC's Avatar
My uncle is a certified welder and has been welding before i was born haha. Hes gonna be the one to do it. But i want to know how straight do i have to get it because im sure it matters...
Old Jan 14, 2008 | 06:34 PM
GSX 4G63T's Avatar
get some white out and make a straight line on a straight area then cut for smooth edges and weld.
Old Jan 14, 2008 | 07:06 PM
i_VTEC's Avatar
Default Re: (4163175587)
Ill try it and see how it turns out! Any more advice???
Old Jan 14, 2008 | 07:13 PM
Hanmin's Avatar
you might need to pull the brakebooster out a little from under the hood to get the bracket to clear out.
Old Jan 14, 2008 | 11:15 PM
i_VTEC's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">you might need to pull the brakebooster out a little from under the hood to get the bracket to clear out.</TD></TR></TABLE>
See its doing S**t like that which i don't wanna have to go through!
Old Jan 15, 2008 | 02:22 AM
zurud's Avatar
You better prepare to buy a new one from dealer. Mine broke twice after welding it. It'll hold a couple months after you weld it, but it'll break again . I bought a new one from dealer cost around 80 shipped.
Old Jan 15, 2008 | 03:33 AM
I CRX I's Avatar
Default Re: (zurud)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zurud &raquo;</TD></TR><TR><TD CLASS="quote">You better prepare to buy a new one from dealer. Mine broke twice after welding it. It'll hold a couple months after you weld it, but it'll break again . I bought a new one from dealer cost around 80 shipped.
</TD></TR></TABLE> ditto, i just bought a new one also. i would recommend buying a new one and welding it then spraying it down with some rustoleum to have that extra support. 80 shipped for me also. but look for "auto to manual pedal swap" in the search, theres a really awesome write up on how to remove the pedal assembly and drop the streering column, it took me about 30-45 mins to do with that write up and the proper tools
Old Jan 15, 2008 | 06:16 AM
mario_pic's Avatar
and theres the reasion i went with a tegy assembly lol
Old Jan 15, 2008 | 06:18 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: HELP! Broken Clutch Pedal Bracket?? (mario_pic)
I have a manual pedal set if you wanna swap the whole thing out.
Old Jan 15, 2008 | 10:05 AM
alscrx's Avatar
Default Re: HELP! Broken Clutch Pedal Bracket?? (-NA-aLL-thE-wAy-)
Just replace the whole thing, You will have to remove anyway to weld all the way around it. I helped a friend remove his cause he sucks with cars. Takes awhile but not that bad. He brought it to a shop and rewelded all the way around it. Well see how long it will last
Old Jan 15, 2008 | 07:35 PM
i_VTEC's Avatar
Default Re: HELP! Broken Clutch Pedal Bracket?? (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Just replace the whole thing, You will have to remove anyway to weld all the way around it. I helped a friend remove his cause he sucks with cars. Takes awhile but not that bad. He brought it to a shop and rewelded all the way around it. Well see how long it will last </TD></TR></TABLE>
I think thats what im going to do. But what all do i have to remove in order to pull it out?
Old Jan 15, 2008 | 07:40 PM
i_VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario_pic &raquo;</TD></TR><TR><TD CLASS="quote">and theres the reasion i went with a tegy assembly lol</TD></TR></TABLE>
What do you mean teggy assembly? It will work?
