Another B16 swap ???
Old Jan 14, 2008 | 04:13 PM
GGcivicEG's Avatar
Default Another B16 swap ???
Iv been lookin around at swap forums and none of the questions I have seem to be answer to clearly, (Or I'm just retarded )
All I need to know. I'm swapping out my D16z6 from 93 coup with a Gen 2 OBD1 B16, Other then rewiring the knock senser can I use the D series wiring harness? Can I use the same plug for the Vtec silinoid as my original harness uses?
As far as Motor mounts, Axles, Halfshafts, and shifter linkage just use all the B series stuff? Thnks.
Old Jan 14, 2008 | 04:31 PM
B164DRDL's Avatar
Default Re: Another B16 swap ??? (GGcivicEG)
yes, you can use your eg harness, you'll just have to extend the vtec wires so they'll reach, and run the KS wire. I've got the same setup in a 92 eg ferio and I used an ex harness
Old Jan 14, 2008 | 04:46 PM
GGcivicEG's Avatar
Default Re: Another B16 swap ??? (B164DRDL)
Thanks sounds good, forgot to add all this is with the B16 ECU. Not sure but from what I read the D16 harness plugs on the ECU are the same as the B16 ECU true or not?
RenX
Jun 1, 2009 05:19 AM
grandtheftlunchbox
Mar 22, 2008 10:37 PM
boostd ls
Apr 12, 2007 05:50 AM
hatchmonkey92
Nov 9, 2003 09:55 AM
SCsol
Feb 25, 2002 01:57 AM
