eh hatch doesn't crank, main relay doesn't click, check engine doesn't come on.
Old Jan 14, 2008 | 12:49 PM
ian.'s Avatar
Default eh hatch doesn't crank, main relay doesn't click, check engine doesn't come on.
Recently stripped my eh to nothing for a full color change put it back together now this is my problem doesn't crank, main relay doesn't click, check engine doesn't come on. any answers? I've been searching for awhile... btw i have a new main relay
Old Jan 14, 2008 | 01:08 PM
Relic1's Avatar
thermostat ground
trans-chassis ground
the ECU controls those things, the ECU gets its ground from the thermostat, the thermostat ground path runs to the battery through the trans-chassis ground.
also check your underhood fuses.
Old Jan 14, 2008 | 01:12 PM
ian.'s Avatar
Default Re: (Relic1)
i think i might need to take more paint off for the tranny ground to the frame iam definately convinced its paint blocking a ground ill try taking a little bit of paint off
Modified by ian. at 6:10 PM 1/14/2008
Old Jan 14, 2008 | 01:16 PM
Relic1's Avatar
quick check for that, a jumper cable clamped to the ground terminal of the battery to the nub of the trans ground. If everything starts working you found the problem.
Old Jan 14, 2008 | 02:11 PM
ian.'s Avatar
it was the tranny ground thanks alot
playertwo
10
Feb 10, 2012 07:14 AM
ef9_lover
Sep 19, 2011 12:08 PM
gnxpro24
59
Apr 15, 2011 05:53 AM
hks_Racing
15
May 14, 2008 07:43 AM
5poonhatch
Aug 19, 2007 07:25 PM
