Coolant Leaking help
Old Jan 14, 2008 | 12:46 PM
Camvill's Avatar
Default Coolant Leaking help
I have coolant leaking from the right side of the engine bay near the timing belt cover but i cant find out where its comming from is it possible to be coming from under the cover??
Old Jan 14, 2008 | 12:50 PM
hades's Avatar
Default Re: Coolant Leaking help (Camvill)
Sure, the water pump is under there... there is also a water pipe that runs the length of the back of the engine that terminates in the same vicinity. (without further info, I'm assuming you have a B or D series in there...)
Old Jan 14, 2008 | 01:13 PM
Cln94EG1's Avatar
Default Re: Coolant Leaking help (hades)
I got home from work and had the same leak but I really hope its not my Water pump. Funny thing is it didnt leak like crazy not even half a cup but I let it cool then started it back up and let it get up to temp rev'ed to 6 3 times then let it run for another 30 mins and no leaks
Old Jan 14, 2008 | 01:38 PM
Camvill's Avatar
yeh i have the 70 hp 1.5l wahtever that one is
dleccord
Jan 11, 2010 06:59 PM
wedtm
Mar 26, 2008 07:59 PM
Random.Hero
Sep 13, 2007 07:56 PM
acteg94
Feb 10, 2004 05:44 PM
