Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Brake Grinding
Old Jan 14, 2008 | 10:20 AM
NiGhTrIIdEr
Guest
Posts: n/a
Default Brake Grinding
I have a 07 si sedan and the other day I was braking and hit a bumb. My brakes felt and sounded like they were grinding badly. I dunno what it is or if its supposed to happen.
Has this happened to any one else?
Old Jan 14, 2008 | 11:39 AM
chiggin's Avatar
Default Re: Brake Grinding (NiGhTrIIdEr)
This isn't a problem. It is your ABS (anti-lock braking system) kicking in. When you hit a bump, the wheel can sometimes loose complete traction very briefly causing ABS to kick in. I just try to not be braking when hitting a bump.
Old Jan 14, 2008 | 02:44 PM
lostjap89's Avatar
i have had this happen to me too. ^^^ sounds like a good explanation
Old Jan 14, 2008 | 03:24 PM
CerealKiller's Avatar
Default Re: Brake Grinding (chiggin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chiggin &raquo;</TD></TR><TR><TD CLASS="quote">This isn't a problem. It is your ABS (anti-lock braking system) kicking in. When you hit a bump, the wheel can sometimes loose complete traction very briefly causing ABS to kick in. I just try to not be braking when hitting a bump.</TD></TR></TABLE>
x2, I hate driving around Whittier,CA when I go for business.
Old Jan 14, 2008 | 03:52 PM
JTRO15's Avatar
ya it happens to me everyday in PA, potholes everywhere
Old Jan 14, 2008 | 07:17 PM
Nighthawk R18's Avatar
Default Re: (JTRO15)
yep, ABS
kinda scary because lots of potholes up here are near traffic lights and if i have to stop for a yellow, ABS kicks in and my wheel hops and sometimes i stop in the middle of the ped crosswalk
Old Jan 14, 2008 | 10:47 PM
lostjap89's Avatar
Default Re: (Nighthawk R18)
that would be scary
Old Jan 14, 2008 | 11:18 PM
reflekt's Avatar
Default Re: (lostjap89)
i also experience this regularly when riding over a bumpy surface. weird thing is, it still happens when i'm driving 2 mph. but yeah, it's definitely the abs
Old Jan 15, 2008 | 11:19 AM
NiGhTrIIdEr
Guest
Posts: n/a
Default Re: (reflekt)
I knew it was ABS that was catching but I didnt know why the hell it was grinding. Thanks now I just dont brake over bumps
thanks for the advice
JesseBizz
Apr 7, 2008 02:19 PM
Progger
Suspension & Brakes
Jul 4, 2006 07:18 AM
EF8 JUNKIE9
Jan 9, 2004 11:19 AM
92HB_HB
Jan 3, 2004 10:44 AM
civileng25
Jul 3, 2003 11:28 PM
