88 SI REX,,,OBD1 GSR.? what do i need to re-pin?? DIY's?
Old Jan 14, 2008 | 09:55 AM
Dead CIVIC's Avatar
Veteran: Army
Default 88 SI REX,,,OBD1 GSR.? what do i need to re-pin?? DIY's?
hey guys I'm almost don with this project, but I'm confused as to how do i make the shock tower plugs work, and the distributor, little things like the fan switch,
if there is a write up on what is done to over come this issue, I'd greatly apreciate it. this is really fonfusing to me.
i currently the grs OBD1 harness and the REX SI OBD0 harness.
I wanna thank you guys in advance for your inpup
Old Jan 14, 2008 | 10:06 AM
CRX Toad's Avatar
Default Re: 88 SI REX,,,OBD1 GSR.? what do i need to re-pin?? DIY's? (Dead CIVIC)
https://honda-tech.com/zerothread/1508680
Old Jan 14, 2008 | 10:40 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: 88 SI REX,,,OBD1 GSR.? what do i need to re-pin?? DIY's? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/1508680</TD></TR></TABLE>
that is some good info.
but I'm not sure whitch ones are specifying the question i asked... my computer is really slow and keeps crashing, can some on help me find my answers.
Old Jan 15, 2008 | 09:46 AM
Dead CIVIC's Avatar
Veteran: Army
bump
Old Jan 15, 2008 | 12:20 PM
PiKapp504's Avatar
Convert your OBD0 harness to OBD1, then it should be "plug-n-play". That's the EASIEST way to do it. Get the OBD0 to OBD1 jumper harness from RyWire, run the appropriate wires, done!
stealthmodeSI
19
Feb 20, 2020 04:06 PM
jordy75
Aug 9, 2010 02:51 PM
kenneth4g4d
Nov 27, 2007 08:05 PM
1truelovedstd
Oct 9, 2005 03:57 PM
hatchback_al
10
Sep 30, 2004 08:40 AM
