B16 XSI Diagram
Old Jan 14, 2008 | 01:35 AM
Bsixteen_CRX's Avatar
Default Im so confused!!!
Im so confused. i need a reliable plumbing diagram for a obd0 b16a out of an integra xsi with a itr intake manifold and stock b16 throttle body. every single one i pull up is different. like gsr, type r, and 99-00 si they all have different coolant lines going to different places. i could really use any info on this problem. thanks
oh yea and the motor is in a 1990 crx si.
Old Jan 14, 2008 | 09:47 AM
wickedEFguy's Avatar
Default Re: Im so confused!!! (Bsixteen_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bsixteen_CRX &raquo;</TD></TR><TR><TD CLASS="quote">Im so confused. i need a reliable plumbing diagram for a obd0 b16a out of an integra xsi with a itr intake manifold and stock b16 throttle body. every single one i pull up is different. like gsr, type r, and 99-00 si they all have different coolant lines going to different places. i could really use any info on this problem. thanks
oh yea and the motor is in a 1990 crx si.</TD></TR></TABLE>'
I have the exact same B16 XSi motor in my 90 CRX Si....All you need to do is follow the diagram from a 90-93 Intregra for coolant and the stock CRX Si vaccum lines and you're golden
Old Jan 14, 2008 | 01:25 PM
Default Re: Im so confused!!! (wickedEFguy)
cool thanks man. does it matter that i have an itr intake manifold?
Old Jan 14, 2008 | 02:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bsixteen_CRX &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks man. does it matter that i have an itr intake manifold?</TD></TR></TABLE>
No, it should be the same unless you're using the ITR throttle body and you'll have the MAP sensor mounted on top of the throttle body versus it being on the firewall for the stock CRX motor.
Old Jan 14, 2008 | 03:13 PM
sloweredcivic's Avatar
agreed were you lucky enough to get an lsd tranny? either way fun swap GL!!
Old Jan 14, 2008 | 07:55 PM
Default Re: (sloweredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">agreed were you lucky enough to get an lsd tranny? either way fun swap GL!!</TD></TR></TABLE>
it didnt come stock with an lsd but i put in viscous one from a civic sirII
Old Jan 15, 2008 | 08:35 PM
stockbee's Avatar
you won't be able to use your FITV that is fitted on your OBD0 intake manifold. That will give you issues while starting your car up and letting it idle in cold weather.
Reason for that is the ITR intake manifold doesn't use the FITV at all.
Old Jan 15, 2008 | 10:30 PM
Default Re: (stockbee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockbee &raquo;</TD></TR><TR><TD CLASS="quote">you won't be able to use your FITV that is fitted on your OBD0 intake manifold. That will give you issues while starting your car up and letting it idle in cold weather.
1 what does FITV stand for and 2 the motor ran and idled perfectly in another crx i had.
Old Jan 16, 2008 | 09:31 AM
stockbee's Avatar
Default Re: (Bsixteen_CRX)
1 what does FITV stand for and 2 the motor ran and idled perfectly in another crx i had.</TD></TR></TABLE>
To answer your questions it stands for Fast Idle Throttle Valve I believe.
I'm glad to hear that it ran good without it in your other car though, I'm putting together a B16A head with an ITR intake manfiold as well. I'm converting it to OBD1 though so maybe that's the issue I'm gonna have to worry about.
Old Jan 16, 2008 | 09:48 AM
MonkeyMagic's Avatar
tip:
see where those coolant lines come out of the block... then to the FITV (Fast Idle Thermal Valve)... then to the IACV (Idle Air Control Valve)... then back to the block?
cap that exit and entrance to the block with vacuum caps and small hose clamps.
then as far as vacuum.. you got two lines on the manifold.. one to the brake booster, one to the fuel pressure regulator. cap anything else. on the throttle body you got one that sticks straight out toward the intake... run that one to the map, cap everything else.
Old Jan 16, 2008 | 07:28 PM
Default Re: Im so confused!!! (MonkeyMagic)
sweet thanks for the tips
Old Jan 16, 2008 | 09:58 PM
stockbee's Avatar
Thanks also,
Im supposing this will allow one to run the ITR intake manifold without the FITV without having the cold start issues?
Old Jan 17, 2008 | 08:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockbee &raquo;</TD></TR><TR><TD CLASS="quote">Thanks also,
Im supposing this will allow one to run the ITR intake manifold without the FITV without having the cold start issues?</TD></TR></TABLE>
well i should have this swap finished within the week. soon as i get the rest of my parts.its snowing where i am so ill let you know on the cold start issue.
Old Jan 18, 2008 | 03:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic &raquo;</TD></TR><TR><TD CLASS="quote">tip:
so with all those lines plugged will my car still idle and run fine in hot and cold weather? cuz its like 20 degrees right now where im at.
civicsitech91
Nov 13, 2006 12:32 PM
category5 SI
Jun 9, 2006 06:05 AM
crx_91si
Mar 1, 2005 07:11 PM
C4wrx
Apr 28, 2002 09:17 AM
