Rear Disc Conversion
Old Jan 13, 2008 | 11:16 PM
Ebrake650's Avatar
Default Rear Disc Convertion
Im planning on doing a rear disc conversion, ive been doing some research and came up that i needed a proportioning valve 40/40. how would i know if i have one already? i have a 90Civic SI. i also need the Ebrake cables any suggestions on what year would fit best? is there anything else i would need?
Old Jan 14, 2008 | 12:45 AM
424racer's Avatar
Default Re: Rear Disc Convertion (Ebrake650)
on the valve it will say 40 on the top and 40 on the bottom.
40-40 ...
just get a ebrake cable for your year. for disc breaks. not drum.
Old Jan 14, 2008 | 03:52 AM
CRX Toad's Avatar
Default Re: Rear Disc Convertion (424racer)
It will be hard for him to get ebrake cables for a 90 Civic Si as they never came with rear disc brakes to begin with. You will need to use Integra 2dr ebrake cables.
https://honda-tech.com/zerothread/1508680
Old Jan 14, 2008 | 04:54 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
its worth your time to goto the larger 88-91 Prelude or 90-91 Non-ABS Integra brake master cylinder as well.
Old Jan 14, 2008 | 07:12 AM
ef-hatchcrap's Avatar
Default Re: (ComeOnKip)
not trying to hijack your thread but I did the da rear disc swap and I got 2 door integra e-brake cables and they dont work?
any suggetions I hvae a 91 dx hatch
Old Jan 14, 2008 | 07:37 AM
ComeOnKip's Avatar
i did DA rear trailing arms and used the ebrake cable without issue.
Old Jan 14, 2008 | 07:46 AM
CRX Toad's Avatar
Some people loop the cables to take the slack out of it which is something that needs to be done so they are taunt.
Old Jan 14, 2008 | 07:57 AM
ComeOnKip's Avatar
maybe cause i have a sedan and you guys have hatches? don't know how that would effect it because the wheelbase is the same
Old Jan 14, 2008 | 12:10 PM
gibsanez's Avatar
I used TA's out of a 4 door teg and the cables worked fine in my hatch.
Old Jan 14, 2008 | 12:18 PM
mike-y's Avatar
Default Re: (gibsanez)
heh, I used cables out of a DC teg and they worked too. I had to move/bend some of the mounting brackets a bit though.
95dxb18b1
Aug 29, 2011 06:47 PM
eg8ynot
Nov 6, 2008 04:43 PM
98GSR-Turbo
May 16, 2008 02:03 PM
Hybrid7
Jun 3, 2005 07:23 PM
untitled
Sep 5, 2003 02:35 PM
