New throttle body= high Idle
Old Jan 13, 2008 | 09:06 PM
black bandit's Avatar
Default New throttle body= high Idle
Alrigtht so my TPS went bad on my throttle body and my buddy had a b16 (I also have a b16) throttle body with the sensors so he gave it to me. I put my car tonight and now my idle is high. It is around 3k rpm. How do I fix the high idle? Also there is one extra nipple on the throttle body on the top and my old on didn't have one. What goes on that nipple? Could this be what is causing my problem? Thanks for the help!
Old Jan 13, 2008 | 10:03 PM
ghettoSi's Avatar
she's cheating on you
Default Re: New throttle body= high Idle (black bandit)
You have a vacum leak, just plug that nipple and you will be fine.
Old Jan 13, 2008 | 10:09 PM
Default Re: New throttle body= high Idle (ghettoSi)
How do i plug it?
Old Jan 13, 2008 | 10:14 PM
ghettoSi's Avatar
Lol. I don't remember what they are called but I had one a while ago and I just bought a little pack of these little rubber caps at like autozone. cost about a dollar
Old Jan 14, 2008 | 04:26 AM
yoffer's Avatar
Banned
Try capping off that nipple you are talking about, its a vacumme port. But if it still persists on high idle, try adjusting your idle using the idle screw located on the throttle body. Screw in to lower idle, unscrew to raise idle. But to properly set it, unplug your iacv, start the car and then adjust the screw to set it around 500rpmish. Then plug back in the iacv and clear the CEL (from unplugging the iacv) and restart it.
magicguy
Jan 30, 2009 02:00 PM
924doorEG
Nov 19, 2007 08:15 AM
FatBoy4door
Oct 20, 2004 09:17 PM
TheHatchHog
May 15, 2003 06:16 AM
