Lighting HID/Xenon kits, Retrofits and Associated Topics
Can you convert HID kit bulb sizes?
Old Jan 13, 2008 | 05:28 PM
Chitown Si's Avatar
Default Can you convert HID kit bulb sizes?
I have an old McCulloch HID kit from my Civic Si which used H4 size bulbs. I was wondering how (if at all) I can get the kit to be used for my RSX foglight size H11? I obviously have to buy H11 size bulbs, but I believe the connection is different. Is there anywhere that sells the clips to use the H4 kit on a H11? or do I just need to buy a whole new H11 kit? I was looking around Xenon Depot.com to see if they sold anything, couldnt find anything.
Thanks
Old Jan 14, 2008 | 02:43 PM
prelude1897's Avatar
Default Re: Can you convert HID kit bulb sizes? (Chitown Si)
if the clips are different with the bulbs and ballast, you could always just splice the wiring together. That's what I had to do when I put H3 bulbs in my fog lights on my Prelude
Old Jan 14, 2008 | 06:45 PM
db8db8db8's Avatar
Default Re: Can you convert HID kit bulb sizes? (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">if the clips are different with the bulbs and ballast, you could always just splice the wiring together. That's what I had to do when I put H3 bulbs in my fog lights on my Prelude</TD></TR></TABLE>
Did it turn out okay? no probs. w/ it at all? I might have to do the same thing with my headlights. I am trying to run a couple of ballast with my 98 civic and have to figure out how to wire everything.
Old Jan 15, 2008 | 10:39 AM
Default Re: Can you convert HID kit bulb sizes? (db8db8db8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8db8db8 &raquo;</TD></TR><TR><TD CLASS="quote">
Did it turn out okay? no probs. w/ it at all? I might have to do the same thing with my headlights. I am trying to run a couple of ballast with my 98 civic and have to figure out how to wire everything. </TD></TR></TABLE>
works great and no problems at all.
Old Jan 15, 2008 | 03:34 PM
honda_kid42's Avatar
glad i found this...i was wanting to do the same and wasnt sure if it would mess the ballast up...
Old Jan 15, 2008 | 07:42 PM
operatic's Avatar
You should just have to buy H11 bulbs and an H11 wiring harness the rest you can reuse.
Old Jan 16, 2008 | 12:06 PM
Chitown Si's Avatar
its no the clips from the bulb to the ballast. it is the connection from the ballast to the car. The H4 looks like a plug you would plug into your house outlet, while the H11 is alot smaller clip connector
Old Jan 21, 2008 | 07:43 PM
kawgomoo's Avatar
when you buy bulbs they will come with the low side connectors that match them... typically buy taichang ie supervision bulbs and they will have what you need to plug n play
02_Si_FTW
Lighting
Jul 5, 2008 07:13 PM
dlprince
Honda Civic (2001 - 2005)
19
Jun 29, 2007 07:10 AM
LSVtecHatchback
Jun 29, 2006 10:32 PM
Killtodie
May 25, 2006 05:31 PM
