Stock Civic Radio
What you can do? Are you able to obtain replacement parts and install said parts?
Probably the only thing you can do is buy another radio on eBay and install it.
In order to get it out, use a bigger pry bar. It'll snap out. j/k.... Seriously, go here: http://www.installdr.com/Insta...3.pdf
Remove the stereo from the car and you will see how to remove the face. There are lots of little clips surrounding it. I've removed them before and it's not all that hard if you take your time.
sounds like you need to get either another stock stereo with the theft code or buy an aftermarket stereo. My advice is to go with an aftermarket stereo.
scottpodj
Aug 19, 2004 09:54 AM
