crx b18 starter problem??
Old Jan 13, 2008 | 05:21 PM
crxricer66's Avatar
Default crx b18 starter problem??
i am thinking about buying a 89 crx si. it has a b18a1 and he says he think it needs a starter. i tried to start it, the pump primes, i turn the key and it doesnt do anything. the pump primes still when i turn the key so does it sound like the starter?? also it sounds like the relay clicks over and over. like the sound of a dead battery kinda.
Old Jan 13, 2008 | 05:25 PM
GSX 4G63T's Avatar
take the starter to a parts store and it have load tested.
Old Jan 13, 2008 | 05:29 PM
crxricer66's Avatar
Default Re: (4163175587)
its not my car and the guy says the starter is gone. im thinkin about buying the car. turn the key, pump primes then turn the key and nothing happens. hold it long enough and it sounds like the main relay clicks very fast.
Old Jan 13, 2008 | 05:38 PM
GSX 4G63T's Avatar
If i were in your situation, I would find a good known starter and install and test it again.
Old Jan 13, 2008 | 05:45 PM
crxricer66's Avatar
ya thats wut im planning for tommorw. hes askin 1000 for it and i offered him 700 and i think hes gonna take it. i told him i would swap him some other parts too. u saw the pics a few minutes ago didnt u?? the topic name was i need some opinions. i jus found out the exhaust is a greddy catback. the way i see it, hasport mounts-500 depending where u buy it, b18a1 swap- 1000-1500, greddy exhaust-400-500. thats worth almost triple the car, thats jus the goodies.
heres some pics
[IMG][/IMG][IMG][/IMG]
Old Jan 13, 2008 | 05:48 PM
GSX 4G63T's Avatar
Default Re: (crxricer66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">ya thats wut im planning for tommorw. hes askin 1000 for it and i offered him 700 and i think hes gonna take it. i told him i would swap him some other parts too. u saw the pics a few minutes ago didnt u?? the topic name was i need some opinions. i jus found out the exhaust is a greddy catback. the way i see it, hasport mounts-500 depending where u buy it, b18a1 swap- 1000-1500, greddy exhaust-400-500. thats worth almost triple the car, thats jus the goodies.
heres some pics
[IMG][/IMG][IMG][/IMG]</TD></TR></TABLE>
yep , i saw that and it got locked up because we can't decide what is best for you and only you i repeat only you can decide what is best for you and your goals
Old Jan 13, 2008 | 05:50 PM
crxricer66's Avatar
im not trying to have u decide. i jus want to no if it sounds like the starter, how i stated above. if it is i will swap it there and drive it home. are b and d starters the same??
Old Jan 13, 2008 | 05:52 PM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">im not trying to have u decide. i jus want to no if it sounds like the starter, how i stated above. if it is i will swap it there and drive it home. are b and d starters the same??</TD></TR></TABLE>
NO!!!!!!!!!!!!!!!!
B series starters are not the same for d series starters.!!!!
Old Jan 13, 2008 | 05:54 PM
GSX 4G63T's Avatar
try autozone.com and plug in 88 honda civic si and then next plug in 2001 acura integra b18c5 type r starter. both part numbers are different. but if you type in 2000 honda civic ex sohc vtec the starter is the same...
Old Jan 13, 2008 | 06:08 PM
crxricer66's Avatar
does the above i stated sound like the starter??? thx for the help man.
Old Jan 13, 2008 | 07:05 PM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 &raquo;</TD></TR><TR><TD CLASS="quote">does the above i stated sound like the starter??? thx for the help man.</TD></TR></TABLE>
no! do you have spark? Remove a plug wire and try see if spark jumps from wire to plug terminal?
Old Jan 13, 2008 | 07:06 PM
GSX 4G63T's Avatar
have a friend try to crank the car over.
J.E.G.
Classic Hondas
Aug 31, 2009 01:27 AM
mugen94
Aug 9, 2009 03:16 PM
KansasKev
11
Jul 26, 2007 01:36 PM
Speedingcivic
Jul 5, 2007 07:55 AM
KtHaNxBai
Jan 26, 2007 09:55 AM
