91 civic backfireing help please
Old Jan 13, 2008 | 04:22 PM
hondacivic121's Avatar
Default 91 civic backfireing help please
my 91 civic hatch back fires when it gets to 5 rpm and i replaced the dizzy checked the timing new wires and spark plugs what else could it be
Old Jan 14, 2008 | 05:46 PM
VeeL_B20's Avatar
Default Re: 91 civic backfireing help please (hondacivic121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic121 &raquo;</TD></TR><TR><TD CLASS="quote">my 91 civic hatch back fires when it gets to 5 rpm and i replaced the dizzy checked the timing new wires and spark plugs what else could it be</TD></TR></TABLE>
I've had that happen to me a couple of times. Do you have a fuel pressure regulator? The most common problem with backfiring is too much fuel gets into the motor and not all of it is burned, the fuel then leaks to the exhaust and BOOM it detonates in the exhaust pipes. If you have a FPR, try lowering the psi, but not too much otherwise you have absolutely no power. lol. GOOD LUCK!!!
Old Jan 14, 2008 | 10:03 PM
nah i dont got a FPR but i did the ECU codes and my ECU is giving me code 74 which is cylinder 4 misfire....so i think it might be a bad fuel injector or cam shaft, i got 3 new injectors today and ima put them on tomorrow and see what happens and it it still does it ill throw a new head on it and hope it works
Old Jan 15, 2008 | 03:34 AM
Darrell Bs 10SecEG's Avatar
If its not your injectors,Try another ecu out and change your spark plugs cause one might be fouled and cant spark to ignite the fuel.That happened to me awhile ago.Good Luck
Old Jan 15, 2008 | 09:22 AM
ive tried a different ECU and my plugs and wires are new i changed them when it started to do this
Old Jan 16, 2008 | 01:35 AM
Default Re: (hondacivic121)
Try changing the Fuel pressure regulator on your fuel rail and see what happens.Also pull out your injectors and see if any of them might be cracked and throwing in extra fuel in the cylinders bro.
Old Jan 21, 2008 | 01:59 PM
Default Re: (Darrell Bs 10SecEG)
wheres the fuel pressure regulator located at
Zack Gunther
Mar 9, 2013 04:59 PM
eppymoto69
May 30, 2011 11:54 PM
panterica
Sep 5, 2010 06:10 PM
7panget
13
May 20, 2007 09:37 AM
gambo117
Aug 6, 2005 03:40 PM
