head gasket ?
okay well i was wondering if you guys could help me out on this and if its broke im gonna bug for a mini me swap but anyways is it a common problem wit honda's to have to add anti freeze like i would say about 3 or 4 days by then it sucks it all out of the over flow doesnt run hot or anything like that though so i dont really understand.
thats the odd thing car really isnt smoking at all so me and my dad would know it was that like right away but since its not we r kinda confused about it
Is it leaking put a piece of card-board under it under something and leave it under it one night. Bottom line, coolant going somewhere, so its either to inside the motor via h/g, or on the outside a leak somewhere.
i havnt ever seen it sitting in my driveway at all though and im kinda stumped on it because i would be able to tell if it was in drive way since we have a cement driveway.
You have two things you need to do. A compression test and a coolant system pressure test.
It could be something as simple as a slightly leaky intake manifold gasket. Seeing a green tint on the spark plugs may be a sign of that or a bad head gasket.
You should be able to find someone with a compression tester, or you can probably rent both tools from checker.
