want to chip my ecu
Need a little help. I have a 92 EG8 D15. Yesterday I dropped an si tranny in it. I was told it will have a little bit of a gear ratio upgrade. but someone told me i need to chip my ecu to actually be able to notice it. can anyone tell me how to do this or what i need to do?
The SI tranny is i think the shortest geared D trans, but I could be wrong. Either way you put it, chances are it's a shorter geared tranny then the one you pulled out, so you should notice it right off the bat. You do not need an ECU chip to feel the difference from a change in gear ratio/FD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch92 »</TD></TR><TR><TD CLASS="quote">last i knew the EX/SI have the same gears. they are shorter than your stock gears so you will get a little bit of acceleration out of it.</TD></TR></TABLE>
EX = .702 5th
Si = .750 5th
Everything else is the same.
EX = .702 5th
Si = .750 5th
big-cat
Mar 14, 2008 08:57 AM
