Clutch in to start?? need help
Old Jan 13, 2008 | 08:16 AM
91H4hatch's Avatar
Default Clutch in to start?? need help
I have a 91 hatch w/ a ZC swap. Lately i have been having to push on the clutch harder and harder for the engine to turn over. Now it wont turn over at all. Is there a sensor i can by pass so i dont have to push the clutch in at all to start the car? or something else, any suggestions....
Old Jan 13, 2008 | 08:38 AM
twiztid17thninja's Avatar
Default Re: Clutch in to start?? need help (91H4hatch)
there is a clutch sensor follow the clutch pedal up and you will find it. (you may need to take out the dash to get to it)
Old Jan 13, 2008 | 09:25 AM
91H4hatch's Avatar
Default Re: Clutch in to start?? need help (twiztid17thninja)
what do i do when i find the sensor?
Old Jan 13, 2008 | 09:37 AM
there is a switch that the pedal hits you could try holding it down with something and starting the car if that doesn't work take it out and link the pins (make the car think the clutch is always down) if neither of these works then replace the switch
edit: use a peice of copper wire or something to link the pins
Old Jan 13, 2008 | 09:55 AM
91H4hatch's Avatar
thanks for the help!! We'll see what happens....
Old Jan 13, 2008 | 11:03 AM
I CRX I's Avatar
check your clutch cable before disabling anything, you dont want your car launching foward on start up. if thats ok, the sensor is threaded i believe, so all you might have to do is screw it in towards the pedal after lossening the lock nut.
Old Jan 13, 2008 | 03:21 PM
redwards's Avatar
i have an 88 and i never have to push my clutch down to start.....is there something wrong or is there no safety swtich on the car???
Old Jan 16, 2008 | 01:16 PM
RiskEverything's Avatar
Default Re: (redwards)
There is no safety switch on the '88s
EGed up from the seat up
Apr 6, 2011 06:33 PM
da9wonder
Sep 7, 2006 03:55 PM
99cpevtec
Jul 15, 2005 02:27 PM
yaleforizzle
Dec 8, 2003 06:34 AM
p0pe
Sep 20, 2003 07:52 PM
