So I have a few issues after I replace engine... Need help on this one guys.
Old Jan 12, 2008 | 11:05 PM
player01018's Avatar
Default So I have a few issues after I replace engine... Need help on this one guys.
Ok first problem.... On my other engine when I hit pedal you can hear it just go now after I put this engine in it goes and all but it sounds like it isnt going till after i hit 4k rpms then it speed up... And that goes for all gears. I believe it might be a fuel to air ratio issue? Also I have maintanence light come on after I drive it for awhile but if I turn car off and back on it wont come on rill im going fast or high rpm? any ideas it is a d15b7. Now one more problem I am having fan issues now it didnt turn on when I had old engine in right but if I hook it up go batery it runs. I checked relay works. I though if I switched engines it would be fine but it isnt what else can I check im out of ideas. Thanks guys and I Will awnser all questions for u.
Old Jan 12, 2008 | 11:31 PM
i_am_a_black_man's Avatar
Default Re: So I have a few issues after I replace engine... Need help on this one guys. (player01018)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by player01018 &raquo;</TD></TR><TR><TD CLASS="quote">Ok first problem.... On my other engine when I hit pedal you can hear it just go now after I put this engine in it goes and all but it sounds like it isnt going till after i hit 4k rpms then it speed up... And that goes for all gears. I believe it might be a fuel to air ratio issue? Also I have maintanence light come on after I drive it for awhile but if I turn car off and back on it wont come on rill im going fast or high rpm? any ideas it is a d15b7. Now one more problem I am having fan issues now it didnt turn on when I had old engine in right but if I hook it up go batery it runs. I checked relay works. I though if I switched engines it would be fine but it isnt what else can I check im out of ideas. Thanks guys and I Will awnser all questions for u.</TD></TR></TABLE>
your question makes no sense at all
oh and only live like 30min from me haha
ActiveAero
Feb 15, 2026 03:06 PM
CaliforniaSnow
Feb 12, 2014 08:00 PM
kaiba
Sep 8, 2005 03:25 PM
jerrywidening
Sep 26, 2004 11:24 AM
