cam with k engraved? identification please!!!
they look like b17 cams because of the 3 rings. check out ff-squad.com then go to the technet section and look at b series cam identification. that should help you.
i did homie and none of the dizzy ends matched mine
and if they had an engraved k on b17 cams they should of posted a pic on that site
i was told they are aftermarket
help pelase i need to sell them soon
Yes the cams should be aftermarket.
But i don't know which.
You could get a measure of the vtec lobes lift to give us some data.
Most aftermarket cams have a solid end.
These cams look to be GSR cams, but not 100% sure. Def a stock looking cam though according to the rings.
i've seen early b16 1st gen cams have K on them, whether they are only 1st gen b16a, i couldn;t tell you.
