itb
Old Jan 12, 2008 | 08:52 PM
i-VTEC_DOHC's Avatar
Default itb
how much would it cost??
and what gains are expected?
Old Jan 12, 2008 | 09:08 PM
risktypeS's Avatar
Default Re: itb (i-VTEC_DOHC)
what are you're goals and what are you trying to accomplish?
You can find the prices on google.com
Old Jan 12, 2008 | 10:44 PM
iVteCmMdc5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">how much would it cost??
and what gains are expected?</TD></TR></TABLE>
Any computer SCEARCHING skills at all??
Old Jan 13, 2008 | 04:51 PM
Pat_S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">and what gains are expected?</TD></TR></TABLE>
I'm assuming it all depends on the tune.
Old Jan 13, 2008 | 07:41 PM
FG2quick's Avatar
Default Re: itb (iVteCmMdc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteCmMdc5 &raquo;</TD></TR><TR><TD CLASS="quote">
Any computer SCEARCHING skills at all??</TD></TR></TABLE>
SCEARCHING skills, probably none, searching skills, not much.
Old Jan 14, 2008 | 11:52 AM
iVteCmMdc5's Avatar
Default Re: itb (FG2quick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FG2quick &raquo;</TD></TR><TR><TD CLASS="quote">
SCEARCHING skills, probably none, searching skills, not much. </TD></TR></TABLE>
lol my spelling skills = none hahah
Old Jan 15, 2008 | 07:48 AM
mymomsdrunk's Avatar
for power gains not much, but better throttle response. go to toda's website the have information there.
Old Jan 15, 2008 | 08:15 AM
FullEP3's Avatar
Default Re: itb (mymomsdrunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mymomsdrunk &raquo;</TD></TR><TR><TD CLASS="quote">for power gains not much, but better throttle response. go to toda's website the have information there.</TD></TR></TABLE>
You're kidding, right???
I've seen gains of 20+ hp in the midrange using Toda ITB's on B-series motors ... gains should be similar or more on K-series
ITB's are better used with an aggressive cam and proper tune ... you'll get your best results with that setup vs using them with a stock motor. The biggest gains will be in midrange hp and torque vs peak numbers ... this is an excellent mod since you will gain a lot of usuable power ... esp needed for road racing applications!
ITB's are not cheap and can be costly to tune properly ... however the gains in performance and sound are amazing!
Old Jan 15, 2008 | 08:19 AM
Todd00's Avatar
I said I don't want a title!
Is your being held back by the stock or Type R intake manifold? If not, then you shouldn't be considering this upgrade.
Also, ITBs are only good for racing applications, not a daily driver.
Old Jan 15, 2008 | 08:46 AM
Default Re: itb (FullEP3)
im just stateing what i read on toda's website thats all.
"Q) I have a completely stock car, how much power will the TODA Sport Injection Kit add?
A) This is a very common question that we get on daily basis. The answer is Sport Injection Kits are designed for cars with extensive modifications. On a stock vehicle, engine only allows certain amount of air to travel through, so by adding Sport Injection Kit, consumers will not see any benefit.
Q) How much power should I expect with TODA Sport Injection Kit? If I have a fully build car?
A) It really depends, the main purpose of the Sport Injection Kit is to increase throttle response at high rpm operation. It was never designed for steet cars that does bumper to bumper daily commutes. We strongly recommend high compression pistons, performance camhshafts, adequate engine management system that reads off the TPS sensor and so on. We are seeing anywhere from 10-20hp increase on smaller displacement vehicles and 40-50 on bigger displacement cars (TODA C35B NSX)."
http://todaracing.com/article?t=6&id=11
Old Jan 15, 2008 | 09:36 AM
blueshark123's Avatar
RBC FTW. ITBs are not worth it unless you have done just about every NA mod, running crazy compression, and your head outflows an RBC. At which point you could get the RBC ported or modded. http://www.blueprintmfg.com/as...=1267
yee SERIOUS
Feb 18, 2008 07:25 AM
turbociv910
Southeast (Sales)
14
Jan 8, 2006 09:51 AM
ihavemoles
Honda S2000
Jun 1, 2005 04:14 PM
