dies when warmed up
i have an 89 crx dx with a 5 speed and the past couple of weeks my car has been dying after the coolant is about 150 degrees. ill start to drive and when vacuum is about 20 (foot barely on the gas) it will start to miss and buck like crazy. it only dies at idle though after it started to buck and miss. does anyone have any idea? thanks
after the car is at idle and its warmed up (full operating temp) youre dumping more fuel to keep the idle and air/fuel mix consistent so to me it sounds like a fuel related issue (fuel pump going bad)... the pump will usually let u turn the car on, but then when u start driving it malfunctions more (bucking). this will get worse and worse until eventually it will completely die. then u buy a walbro 255
check to make sure you're getting fuel and spark.
Modified by saikouEF8 at 10:01 PM 1/12/2008
Mine was just doing this (I bought it this way), and I pulled the plugs, they looked like ***, put in new plugs, and it now runs great. Mine was undrivable when warm, ran great when cold! I would look at basic tune up stuff first.
Edit: I didn't see that you were also the second poster anmd already covered this.
see i was thinking pump too. im gonna go and get a fp gauge and hook it up and hopefully it will die on me and let me know whats goin on. it seems like its more random now. i started my car and drove about 2 miles when it all of a sudden just died, but before it died the tac went to 0 and all the lights turned off, no oil pressure light or battery light. thanks for the help guys. ill keep you informed
no which is the weird thing. but i think its not gonna light one up cus it does it intermittently. when it starts to die i try to give it gas but wont run. im gonna check the tps, cts, and fuel pressure today at work and see whats goin on with it
well i figured out the problem, its the coil. but the other coil i have is for a mpfi distributor and the part number is off by one number. do you think i can still use it in the dx distributor.
ShawnS4363
Mar 24, 2008 05:39 PM
doublethink
Nov 6, 2004 01:10 PM
