Wiring home-made shift light
Old Jun 30, 2002 | 03:35 PM
TodaSi's Avatar
Default Wiring home-made shift light
I have a quick question.
My Civic CX doesn't have a clock in it, but behind the dash trim piece there is a harness clip for the clock. Can I wire up something like a shift light to the 12v power and ground wires on that useless clip? (BTW That trim piece is where I'm gonna put the light.) The shift light needs a switched 12v and ground, then a tach wire to get it to work.
Also, anyone know where to tap into a tach wire to hook up a shift light?
Thanks for all the help.
Old Jun 30, 2002 | 03:55 PM
TurboBumblBee's Avatar
Default Re: Wiring home-made shift light (TodaSi)
Yes you can use that power source w/ no problem.. as for the tach signal you can run the wire to the drivers side strut tower wiring harness and tap into the blue wire..
Old Jun 30, 2002 | 03:58 PM
Chugger's Avatar
Default Re: Wiring home-made shift light (95CivicEX)
what kinda light are you goin to use i am interested in this idea too let us know how it turns out
lata
chris
Old Jun 30, 2002 | 04:03 PM
TodaSi's Avatar
Default Re: Wiring home-made shift light (01VaS2K)
Here is the link to where I got it from.
It was $50.00, so I figured what the hell.
http://www.harlan-engineering.com/store/store.html
Old Jun 30, 2002 | 04:18 PM
TodaSi's Avatar
Just checking. The blue wire with the cap/termination on it in the 1st picture
Or the blue/black wire in this picture below the blue wire.
Old Jun 30, 2002 | 04:20 PM
JaeOne3345's Avatar
blue one with the cap buddy ..its a dealer test wire or some **** from what i heard dont take it as fact but yes thats the one to tap for rpm signal
Old Jun 30, 2002 | 04:22 PM
TodaSi's Avatar
Default Re: Wiring home-made shift light (JaeOne3345)
Aren't digital cameras great or what?!
Thanks for the help.
Old Jun 30, 2002 | 05:07 PM
.Ryan's Avatar
Don't Trust Anyone
I made my Interior Headlamp come on for a shift light, its tiiite. =x
Old Jun 30, 2002 | 05:22 PM
civicmark's Avatar
Default Re: Wiring home-made shift light (SpoonSportsEF7)
would you mind sharing with us, how you did this?
thanks
sounds pretty nice though
Old Jun 30, 2002 | 05:40 PM
Ricey McRicerton's Avatar
Default Re: Wiring home-made shift light (civicmark)
hahah i dont know how much id be willing to do that...sounds kinda dangerous
Old Jun 30, 2002 | 05:44 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Wiring home-made shift light (Ricey McRicerton)
I was Joking....Im not that ghetto!
Old Jun 30, 2002 | 06:38 PM
TodaSi's Avatar
Here is the light mounted. I may move it as it's not in the best spot right now, but still looks good enough.
BTW, I couldn't center the light in the trim plug because of the attachment points on the back.
[Modified by TodaSi, 10:40 PM 6/30/2002]
tscook3
Audio / Security / Video
Mar 13, 2012 05:58 PM
k3vin337
Mar 9, 2008 07:16 PM
HandicapRacer
Jun 24, 2006 06:12 AM
ANVIL
May 15, 2004 08:14 AM
arcboy
Jan 10, 2002 05:59 PM
