transmission problem
i have a 95 honda accord manual trans..
my trans. oil is leaking but i am not sure if its from the drain plug or from the screw next to it on the bottom
look at image
the number 10 screw thats the drain plug theres another screw in the bottom on mine i am not sure which one is leaking from???
i did change my oil and put in new oil
thanks!!
look at image
thanks!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesk18 »</TD></TR><TR><TD CLASS="quote">i did change my oil and put in new oil </TD></TR></TABLE>
Did you replace the aluminum crush washer on the drain plug with a new one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Did you replace the aluminum crush washer on the drain plug with a new one?</TD></TR></TABLE>
nope it doesnt have one i dont remember seen one or putting one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesk18 »</TD></TR><TR><TD CLASS="quote">nope it doesnt have one i dont remember seen one or putting one.</TD></TR></TABLE>
Well, you may have been able to figure out what the likely problem is then . . .
Well, you may have been able to figure out what the likely problem is then . . .</TD></TR></TABLE>
i am hoping that the missing washer is the problem
thanks
thanks
well i change the washer and it did had a washer in there, it was hard to take off the old washer so i used a flat screw driver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">did it stop the leak?</TD></TR></TABLE>
well i check it and it stills drips oil!!
Modified by wesk18 at 2:51 PM 1/16/2008
Modified by wesk18 at 2:51 PM 1/16/2008</TD></TR></TABLE>
i took it to be check and they told me its a driveaxle oil seals from the right side where the right axle goes in.
do u guys think that might be the problem
do u guys think that might be the problem</TD></TR></TABLE>
yes. if you pulled your own axle and it got messed up then theres your problem. im not sure how common they go back by themselfs though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesk18 »</TD></TR><TR><TD CLASS="quote">i took it to be check and they told me its a driveaxle oil seals from the right side where the right axle goes in.
It is quite possible, considering the axle seal is directly above the drain plug. Does it look like that's where the oil is coming from?
Axle seals are not expensive, but you have to remove the axle to install one. If you have all the correct tools and have changed an axle before, it shouldn't take you more than an hour. If you haven't removed an axle before, I'd suggest having a more experienced buddy help you out and show you how to do it without damaging the ball joint. You will need a 36mm socket (preferably with a pneumatic impact gun powering it) and a ball joint separator. Some folks can pop the ball joint free without a special tool.
Axle seals are not expensive, but you have to remove the axle to install one. If you have all the correct tools and have changed an axle before, it shouldn't take you more than an hour. If you haven't removed an axle before, I'd suggest having a more experienced buddy help you out and show you how to do it without damaging the ball joint. You will need a 36mm socket (preferably with a pneumatic impact gun powering it) and a ball joint separator. Some folks can pop the ball joint free without a special tool.</TD></TR></TABLE>
okay so i am telling my buddy to do it for me he did my left axle, about the seal how can i find it in autozone online under what name it might be
yes. if you pulled your own axle and it got messed up then theres your problem. im not sure how common they go back by themselfs though.</TD></TR></TABLE>
i am guessing that right axle is going bad cuz we found grease in some areas and it was hit in that right fender section from the previous owner so i am guessing thats my problem
I'm not sure about AutoZone, but the OE part number for a '95 Accord 5MT right axle seal is 91206-PX5-005 and it should cost you $7.55 at any Honda dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">I'm not sure about AutoZone, but the OE part number for a '95 Accord 5MT right axle seal is 91206-PX5-005 and it should cost you $7.55 at any Honda dealership.</TD></TR></TABLE>
my trans only needs one for the right side only right not the left?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wesk18 »</TD></TR><TR><TD CLASS="quote">my trans only needs one for the right side only right not the left?</TD></TR></TABLE>
Is the left axle seal leaking?
If so, change the left one too. You will need to remove both axles in that case.
If so, change the left one too. You will need to remove both axles in that case.</TD></TR></TABLE>
okay kool
thanks i am going to try that hope thats the problem
okay kool
thanks</TD></TR></TABLE>
WASHERS seem to be such a minor thing, but they are very crucial when it comes to automobiles. just my .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7tuned »</TD></TR><TR><TD CLASS="quote">
WASHERS seem to be such a minor thing, but they are very crucial when it comes to automobiles. just my .02</TD></TR></TABLE>
its a seal where the axles goes
