type r pistons going in a gsr
Old Jan 12, 2008 | 01:17 PM
knuckk's Avatar
Default type r pistons going in a gsr
im getting a gsr shortblock from a friend of mine he says i might as well build it over and ive been thinking about type r pistons do they fit or do i have to bore the block to get them to fit and this is going in a gsr
Old Jan 12, 2008 | 02:17 PM
knuckk's Avatar
anyone?
Old Jan 12, 2008 | 08:00 PM
knuckk's Avatar
Old Jan 13, 2008 | 01:31 PM
DOHc SIdE's Avatar
Default Re: (knuckk)
They will fit fine unless you get the overbore ones which then you would
have to get the block bored.
std=81.00
overbore=81.25
Old Jan 13, 2008 | 05:23 PM
StorminMatt's Avatar
Default Re: (DOHc SIdE)
Also consider that, while standard sized pistons MIGHT fit, they might not fit well. Chances are your block is not very fresh. And just trying to hone it will not correct such things as taper and out-of-round. Honing alone can even worsen things by increasing piston to cylinder clearance. Do yourself a favor, buy oversize pistons, and get the block bored. Alot of time, money, and effort goes into building an engine. Don't skimp by not doing something this important.
oranginal
Jun 23, 2006 10:19 PM
chanksta06
May 15, 2006 08:24 PM
civic_d16y7
Apr 2, 2005 05:08 PM
neferlose
Mar 23, 2005 07:13 AM
TypeR0149
Aug 31, 2001 12:53 PM
