ASR and 32mm Sway bar opinions
hey guys im looking into finishing up my suspension on my car by getting the ASR subframe brace and rear swaybar. I was looking at a kit i can buy with everything needed to just bolt up to my brace and LCA's. The only thing i have heard about this setup is it is really stiff and isnt reccomended for DD. i just wanted to get some opinions on this/ if anyone has this setup what they think about it.
Heres my setup so far....
Omni power full coilovers street (10k/8k)
AC autotechnic CF front upper strut bar
Mugen knock off rear upper strut bar
Skunk 2 LCA's
Looking to add...
ASR subframe brace
32mm hollow bar or 22mm sway bar.
heres a pic of the 32mm kit
THANKS FOR THE HELP
Skunk 2 LCA's
Looking to add...
ASR subframe brace
THANKS FOR THE HELP
do you think i would notice the difference between a 24mm bar and 22mm bar? i can get a kit w/ the itr bar for $330.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">hey guys im looking into finishing up my suspension on my car by getting the ASR subframe brace and rear swaybar. I was looking at a kit i can buy with everything needed to just bolt up to my brace and LCA's. The only thing i have heard about this setup is it is really stiff and isnt reccomended for DD. i just wanted to get some opinions on this/ if anyone has this setup what they think about it.
Skunk 2 LCA's
Looking to add...
ASR subframe brace
THANKS FOR THE HELP
the 22mm or the 24mm kit will be best suitable for DD. with the 32mm you will have to much oversteer. especially with the setup you have now for your suspension.
Skunk 2 LCA's
Looking to add...
ASR subframe brace
THANKS FOR THE HELP
</TD></TR></TABLE>the 22mm or the 24mm kit will be best suitable for DD. with the 32mm you will have to much oversteer. especially with the setup you have now for your suspension.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">do you think i would notice the difference between a 24mm bar and 22mm bar? i can get a kit w/ the itr bar for $330.</TD></TR></TABLE>
If you have a front sway bar, I'd recommend going for the 24mm. If not, the 22mm is fine.
I had a 24mm front/22mm rear on my hatch and it felt like it understeered a little more. If ASR had the 24mm rear sway when I was putting together my suspension, I would have bought it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
I had a 24mm front/22mm rear on my hatch and it felt like it understeered a little more. If ASR had the 24mm rear sway when I was putting together my suspension, I would have bought it.</TD></TR></TABLE>
okay thanks man. yea my car is a 93 ex so it has the front swaybar. ill go with that 24mm bar kit... looks pretty damn sick.
1 Special CTR
Dec 19, 2004 02:18 AM
