no header? less power?
Old Jan 12, 2008 | 09:48 AM
evolutiongsr's Avatar
Default no header? less power?
alright...i will be getting my brother's k20a3 soon..and i wish to gain more power ..i remember reading lots of forum ..and they said that to gain horsepower you must get RID of BACK PRESSURE..so by taking out the header or exhaust i would gain more power? or will i lose it?
thank you
ek 96
Old Jan 12, 2008 | 10:09 AM
RIZOBIZERT's Avatar
Default Re: no header? less power? (evolutiongsr)
Keep the exhaust/header. You want a vacuum effect from the header. When one exhaust pulse passes out the tailpipe it should create a vacuum behind it generating less resistance for the next pulse. Think of a semi truck and you are behind it. You will get better gas mileage as a result of drafting. Well, the exhaust gases are doing the same thing if done right. It can get really complicated, but go with a good name brand and ask some questions of people who have items already installed to see how they like them. Yes, it's just piping, but can be complicated. Exhaust gas flow, velocity, etc. Good luck.
Old Jan 12, 2008 | 10:50 AM
MilanoCivic97's Avatar
Default Re: no header? less power? (RIZOBIZERT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIZOBIZERT &raquo;</TD></TR><TR><TD CLASS="quote">Keep the exhaust/header. You want a vacuum effect from the header. When one exhaust pulse passes out the tailpipe it should create a vacuum behind it generating less resistance for the next pulse. Think of a semi truck and you are behind it. You will get better gas mileage as a result of drafting. Well, the exhaust gases are doing the same thing if done right. It can get really complicated, but go with a good name brand and ask some questions of people who have items already installed to see how they like them. Yes, it's just piping, but can be complicated. Exhaust gas flow, velocity, etc. Good luck.</TD></TR></TABLE>
damn near perfect explanation.
Old Jan 12, 2008 | 10:53 AM
Scott.'s Avatar
tehehe run it with no exhaust at all.....not one bit of backpressure =]..............but seriously...listen to riz
Old Jan 12, 2008 | 10:56 AM
z6hatchboy's Avatar
perfect answer, this is also called the "scavaging effect" i think. Its not good to run no header.
Old Jan 12, 2008 | 01:25 PM
obuhmyuh's Avatar
Default Re: no header? less power? (z6hatchboy)
and its loud as ****, don't be that guy.
RaceCarRyne
Nov 9, 2009 08:22 PM
Rinsta
Jun 24, 2009 01:48 PM
91preyludesi
Oct 29, 2005 12:20 PM
Telega C 33
May 22, 2005 05:08 PM
972drcordex
Jul 19, 2004 10:53 PM
