Soft brakes?
Old Jan 12, 2008 | 07:58 AM
GSR_Hatch8's Avatar
Default Soft brakes Help??
Okay guys, here's the problem I have been having. This is a 93 Honda Civic EX 2dr too. I replaced my brakes and I have bled them several times but the pedal has barely any pressure. When I turn the car off the pressure builds right back up and the pedal is firm, but when I turn it right back on, it immediately gets soft. I've changed the booster check valve and the master cylinder, but neither have alleviated the problem. Does anyone believe that the brake booster is what is causing the problem?
Thanks for the help.
-Nick-
Old Jan 12, 2008 | 08:04 AM
Hatch92's Avatar
it could be the booster. however does the car stop normally with the soft pedal?
Old Jan 12, 2008 | 08:06 AM
GSR_Hatch8's Avatar
Default Re: (Hatch92)
No, braking has definitely diminished.
Old Jan 12, 2008 | 08:14 AM
tensecpass's Avatar
Default Re: (GSR_Hatch8)
when you were bleeding them was the car running?
Old Jan 12, 2008 | 08:22 AM
d357r0y's Avatar
Default Re: Soft brakes Help?? (GSR_Hatch8)
Sounds like you still have air in the lines, are you following the recommended sequence? (LF RF RR LR) You can also tap the caliper with a hammer or screwdriver handle to get the tiny bubbles out. You shouldn't have to bleed more than once if you do it right.
Old Jan 12, 2008 | 08:27 AM
GSR_Hatch8's Avatar
Default Re: Soft brakes Help?? (d357r0y)
Yes I bled them while the car was running and in that order as well.
Old Jan 12, 2008 | 08:32 AM
tensecpass's Avatar
try bleeding them with the car off. thats how ive done my truck as well as mustang and honda and have never had a problem, also tap the calipers(like said above) that usually helps...and dont try and do it by urself get someone to help you
Old Jan 12, 2008 | 09:16 AM
sal_187's Avatar
Default Re: Soft brakes Help?? (tensecpass)
I have always bled the brakes with car switched off and not had any problems so far. Maybe give this a try and let us know how you get on.
Old Jan 12, 2008 | 01:13 PM
GSR_Hatch8's Avatar
Default Re: Soft brakes Help?? (sal_187)
I replaced the brake booster and that did the trick. Thanks for the suggestions.
Ueichi
Feb 25, 2011 02:25 PM
1sikhatch
Dec 7, 2009 04:18 AM
jonshonda
Jan 9, 2007 04:15 PM
jonshonda
Sep 19, 2006 02:33 PM
peja43916
38
Dec 25, 2004 10:42 AM
