Why doesn't the EG/DC rear suspension swap over to the EK?
Old Jan 11, 2008 | 06:14 PM
wade's Avatar
Default Why doesn't the EG/DC rear suspension swap over to the EK?
as stated in title, why doesn't EG/DC rear suspension cross over to EKs?
Old Jan 11, 2008 | 06:21 PM
z6hatchboy's Avatar
Default Re: Why doesn't the EG/DC rear suspension swap over to the EK? (wade)
First, i found that the eg rear lca's are about 1" shorter than the ek. If your including that in the suspension you mentioned.
Old Jan 11, 2008 | 06:26 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Its the LCA thats diffrent.
Old Jan 11, 2008 | 06:27 PM
wade's Avatar
Default Re: (phyzJunkieCivic)
Can the susp be made to work? if so,what is the work needing to be performed?
Old Jan 11, 2008 | 07:00 PM
bmoua's Avatar
Default Re: (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">Can the susp be made to work? if so,what is the work needing to be performed?</TD></TR></TABLE>
whats the reason for this mod bro??? more info plz
Old Jan 11, 2008 | 07:04 PM
wade's Avatar
Default Re: (bmoua)
no one ever has the damn OMNI drag suspension for the rear on EK. But i know of like 3 sets of EG rear OMNI drags for sale
Old Jan 11, 2008 | 07:13 PM
If you use the eg suspensions, with you ek lca you can try to cut the metal thats surrounded buy the rubber bushings. If thats what your trying to do?
Old Jan 11, 2008 | 07:18 PM
HondamanXxX's Avatar
GO GIANTS!
OMNI Drag FTW. Look around the drag racing section bro
Old Jan 11, 2008 | 07:21 PM
wade's Avatar
Default Re: (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">OMNI Drag FTW. Look around the drag racing section bro</TD></TR></TABLE>
i know, i am there all the time. All i ever seem them for is EG/DC
I hear i can make the EGs work pretty simply for the EK chassis now.
I hear the EK rear LCA bushing is thinner than the EG/DC shock fork ( so there is a small gap between the two ). so I just need to use a washer or two to fill between the wider shock fork and thinner bushing.
Old Jan 11, 2008 | 07:24 PM
Luserkid's Avatar
Default Re: (wade)
If you get some thick washers you should be fine. I know some coil over set are the same for 92-95 and 96-00 for the rears, but they add some fatty washers for them.
Old Jan 11, 2008 | 07:25 PM
wade's Avatar
Default Re: (Luserkid)
awesome. How much gap is there exactly?
Old Jan 11, 2008 | 07:26 PM
Some times they so fat, I have to shave the washers sometimes.
Old Jan 11, 2008 | 07:28 PM
Lord wtf am i saying/
Old Jan 11, 2008 | 07:30 PM
wade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic &raquo;</TD></TR><TR><TD CLASS="quote">Lord wtf am i saying/ </TD></TR></TABLE>
you are saying the EK bushings are too wide for the EG shock mount forks. BUT, i hear from everyone else its the EK bushings that are too narrow for the EG shock mounts, thus needing washers to fill the gap.
Old Jan 11, 2008 | 07:31 PM
Luserkid's Avatar
I think i have a set of the washers floating around the garage. If you dont get an answer tomorrow PM me and ill measure them for you.
Old Jan 11, 2008 | 07:38 PM
wade's Avatar
thanks
Old Jan 11, 2008 | 07:39 PM
The front shocks from the eg and ek are all the same and will fit fine.
The rear, if your useing eg shocks with eK LCA you will need spacers.
Old Jan 11, 2008 | 07:43 PM
wade's Avatar
thanks folks
here is a pic of the car
Old Jan 11, 2008 | 07:57 PM
Default Re: (wade)
Sick civic,
From your sig... Tony1 is the bomb, in tuneing cars.
Old Jan 11, 2008 | 08:05 PM
wade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic &raquo;</TD></TR><TR><TD CLASS="quote">Sick civic,
From your sig... Tony1 is the bomb, in tuneing cars. </TD></TR></TABLE>
hes a solJa. known im a while now, hooks me up with free ***** sometimes
Old Jan 11, 2008 | 08:10 PM
user 98292739's Avatar
all you need is 10 mm spacers.
i went to lowes and got 6 spacers(10mm total) 3 on each side and got eg suspension on my ek.
Old Jan 12, 2008 | 08:15 AM
darkclark's Avatar
Default Re: (wade)
where did you ge the front end and what is it called
Old Jan 12, 2008 | 10:12 AM
De_tour's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I think i have a set of the washers floating around the garage. If you dont get an answer tomorrow PM me and ill measure them for you. </TD></TR></TABLE>
Make sure to use Gr.8 washers
Modified by De_tour at 11:28 AM 1/12/2008
Old Jan 12, 2008 | 05:22 PM
wade's Avatar
http://i139.photobucket.com/al...K.jpg
Old Jan 12, 2008 | 05:58 PM
gsrturbo-ek's Avatar
Default Re: (wade)
I hear the EK rear LCA bushing is thinner than the EG/DC shock fork ( so there is a small gap between the two ). so I just need to use a washer or two to fill between the wider shock fork and thinner bushing.</TD></TR></TABLE>
answered your own question right there
