Why doesn't the EG/DC rear suspension swap over to the EK?
Re: Why doesn't the EG/DC rear suspension swap over to the EK? (wade)
First, i found that the eg rear lca's are about 1" shorter than the ek. If your including that in the suspension you mentioned.
Re: (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">Can the susp be made to work? if so,what is the work needing to be performed?</TD></TR></TABLE>
whats the reason for this mod bro??? more info plz
Location: Dont You Just Love Lynn Cops, Boston MA, USMA
If you use the eg suspensions, with you ek lca you can try to cut the metal thats surrounded buy the rubber bushings. If thats what your trying to do?
Re: (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX »</TD></TR><TR><TD CLASS="quote">OMNI Drag FTW. Look around the drag racing section bro</TD></TR></TABLE>
i know, i am there all the time. All i ever seem them for is EG/DC
I hear i can make the EGs work pretty simply for the EK chassis now.
I hear the EK rear LCA bushing is thinner than the EG/DC shock fork ( so there is a small gap between the two ). so I just need to use a washer or two to fill between the wider shock fork and thinner bushing.
Re: (wade)
If you get some thick washers you should be fine. I know some coil over set are the same for 92-95 and 96-00 for the rears, but they add some fatty washers for them.
Re: (phyzJunkieCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic »</TD></TR><TR><TD CLASS="quote">Lord wtf am i saying/ </TD></TR></TABLE>
you are saying the EK bushings are too wide for the EG shock mount forks. BUT, i hear from everyone else its the EK bushings that are too narrow for the EG shock mounts, thus needing washers to fill the gap.
Re: (Luserkid)
The front shocks from the eg and ek are all the same and will fit fine.
The rear, if your useing eg shocks with eK LCA you will need spacers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phyzJunkieCivic »</TD></TR><TR><TD CLASS="quote">Sick civic,
From your sig... Tony1 is the bomb, in tuneing cars. </TD></TR></TABLE>
hes a solJa. known im a while now, hooks me up with free ***** sometimes
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I think i have a set of the washers floating around the garage. If you dont get an answer tomorrow PM me and ill measure them for you. </TD></TR></TABLE>
Make sure to use Gr.8 washers
Modified by De_tour at 11:28 AM 1/12/2008
Re: (wade)
I hear the EK rear LCA bushing is thinner than the EG/DC shock fork ( so there is a small gap between the two ). so I just need to use a washer or two to fill between the wider shock fork and thinner bushing.</TD></TR></TABLE>
answered your own question right there
