needs trouble codes fixed. but don't know where to start.
Old Jan 11, 2008 | 04:46 PM
racingcrx's Avatar
Default needs trouble codes fixed. but don't know where to start.
ok the trouble codes are code 8 tdc sensor. and code 20 electrical load detector.
this is on a HF engine with a HF ecu. and i have no clue where to start. any info would helpme alot.
TIA
Old Jan 11, 2008 | 05:09 PM
racingcrx's Avatar
i do not have a crx manual. so any info would help
Old Jan 11, 2008 | 06:06 PM
GSX 4G63T's Avatar
http://www.hondacivicforum.com/m_45386/tm.htm
Old Jan 11, 2008 | 07:26 PM
Crx Jimmy's Avatar
Default Re: needs trouble codes fixed. but don't know where to start. (racingcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingcrx &raquo;</TD></TR><TR><TD CLASS="quote">ok the trouble codes are code 8 tdc sensor. and code 20 electrical load detector.
TIA</TD></TR></TABLE>
The best I could guess would be to try and swap a dizzy with a known good one.
The eld is part of the underhood fuse box, also try and swap with a known good one
Old Jan 12, 2008 | 07:25 AM
racingcrx's Avatar
well the thing is i have a new distributor on there now. and these 2 codes are still there.
Old Jan 12, 2008 | 08:08 AM
TeamRedline89Hatch's Avatar
Default Re: (racingcrx)
Have you reset the ECU after you replaced the dizzy?
Old Jan 12, 2008 | 02:43 PM
racingcrx's Avatar
no i didn't. but would that make a difference at all???
Old Jan 12, 2008 | 02:53 PM
GSX 4G63T's Avatar
You can reset the ecu by removing the negative battery cable and hold the cable for 10 secs and then tighten it back on post and turn key on to START position. Wait til light goes out then RUN position the ECu is reset. You can also remove #10 fuse for 10 secs.
89civichatchback
Feb 26, 2005 03:44 PM
Gumbey75
Jan 17, 2005 10:57 AM
deftones0817
May 10, 2004 04:16 PM
chirp2hrd
Jun 16, 2003 06:47 PM
pdiddyparsons
Apr 16, 2003 07:07 PM
