how to install autostart
Old Jan 11, 2008 | 03:08 PM
preludepower01's Avatar
Default how to install autostart
i have a 01 honda prelude and i want to have autostart but its a 5 speed so the shop will not do it (i do have a viper alarm system that allows me to have autostart) if any one can help thanks
Old Jan 11, 2008 | 07:40 PM
92hondalude's Avatar
Default Re: how to install autostart (preludepower01)
have you tried going to the viper website and looking up your viper model number?
They should have some PDF manuals i would imagine
Old Jan 11, 2008 | 09:04 PM
ethereal2pt2's Avatar
Default Re: how to install autostart (92hondalude)
just think twice before doing this. it only takes a single mistake.
Old Jan 12, 2008 | 05:55 AM
s_vares's Avatar
I sell starters as i work for an electronic store.
Viper does not make a model that will work with a standard and it is very dangerous to put an auto starter in a manual. You also need a bypass module installed as the 97-01 prelude has an ignition security system.
rethink this with maybe an "autostart" product as they can be used in an auto or standard.
http://www.autostart.com
steve
Old Jan 12, 2008 | 12:35 PM
Default Re: (s_vares)
thanks for the info
Old Jan 12, 2008 | 12:54 PM
Jos3ph's Avatar
Default Re: (preludepower01)
I highly recommend not installing an autostart in a manual transmission car. My friend had one in his 98 prelude and accidently left his clutch in first gear (car was parked on a sloped driveway). His sister autostarted the car the next morning, not knowing it was in gear, and the car went through the garage door.
Old Jan 12, 2008 | 03:09 PM
slamdlude's Avatar
Default Re: (Jos3ph)
I have a 4th gen manual with remote start and i love it. Summer time in Alabama can be brutal if you have to get into a car that is 125 degrees inside. Just don't ever leave it in gear when you shut it off. Trust me it will only take one time of leaving it in gear and you won't ever do it again. If you have a 5th gen then you are going to have to bypass the immobilizer system or disable it to use remote start.
Old Jan 12, 2008 | 05:34 PM
Default Re: (slamdlude)
so how do i do it? dose any one have or know the step by step on how to do it?
Thanks for all the input
Old Jan 12, 2008 | 09:29 PM
blacklude98's Avatar
still, i wouldnt do it...i was thinking of this myself after having to deal with the coldest morning in a long time, but after talking to some people, i realized it's definately not worth it-especially because I'm a forgetful person sometimes, especially while in a rush, so I would not feel good knowing what could happen.
ur choice tho...
srry i dont know how to put it in tho...that's why i opened the thread in the 1st place lol
Old Jan 13, 2008 | 01:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jos3ph &raquo;</TD></TR><TR><TD CLASS="quote">I highly recommend not installing an autostart in a manual transmission car. My friend had one in his 98 prelude and accidently left his clutch in first gear (car was parked on a sloped driveway). His sister autostarted the car the next morning, not knowing it was in gear, and the car went through the garage door. </TD></TR></TABLE>
fyi you don't leave your clutch in first gear lol
but that's exactly why i wouldnt. the advantages of an autostart isnt so advantageous imo. at the very least i would never leave my car running unattended. my car warms up in 2 mins anyway.
Old Jan 13, 2008 | 04:25 AM
Pilky's Avatar
Default Re: (ethereal2pt2)
Look into Compustar remote starters. With these, its impossible to start the car in gear.
Old Jan 13, 2008 | 04:44 AM
Acidcrakker's Avatar
Default Re: (Pilky)
Wouldnt the car stall itself out if it turned on while in gear?
Old Jan 13, 2008 | 07:28 AM
Pilky's Avatar
Default Re: (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Wouldnt the car stall itself out if it turned on while in gear?</TD></TR></TABLE>
No it will buck forward.
Old Jan 14, 2008 | 03:14 PM
slamdlude's Avatar
Default Re: (Pilky)
Why not ask the guys in the audio video and security forum for help. They could probably help more than we can in the prelude forum.
Old Jan 15, 2008 | 03:20 PM
i did and thay did but i wanted to know if any one with a prelude has done it and new how to do it.
Old Jan 16, 2008 | 07:29 AM
slamdlude's Avatar
My local honda dealership will let anyone look at and make copies of their service manuals. Ask your local dealer if they do the same. If so make copies of the ignition wiring diagram and the viper system should come with instructions on which wires go where. Wiring in an alarm sytem is not the most difficult job to undertake. A few scotch locks and some zip ties maybe a pair of side cutters is all you need. Don't forget the box that goes under the dash with a key to your car in it to bypass the immobilizer.
Old Jan 16, 2008 | 08:08 AM
Dicorp's Avatar
i wouldn't bother with an auto start on a manual. if its one of the simpler ones, you run into a possibility of forgeting to leave it in gear. if its one of those smart ones, they make you jump through all sort of procedures before you get out. annoying imo. i'd rather run out of the house 5 mins early, start it, run back in. works every time and doesnt cost anything
preludepower01
Audio / Security / Video
13
Jan 16, 2008 05:59 AM
freezingcoffee
Dec 19, 2005 09:52 AM
db8xc1x39
Northern California (Sales)
42
Oct 28, 2005 03:01 PM
hoehouseworker
Nov 29, 2004 09:25 PM
PreLusion
Nov 30, 2001 10:47 AM
